hello i have this code, its chess engine by Andre Adrian
im having trouble with Separating the result and save it into tow char for example : (e2e4) to first char =e2 and second char = e4
any help ? and thnx
chess_program.ino (11.2 KB)
any help ? and thnx
are you literally meaning a char ? ie 0xE2 and 0xE4 (a byte) or do you mean strings "E2" and "E4"?
Is it this piece of code? If not, point out where it is in your code.
int r;
// Take move from human
while (stringComplete == false) {
getserialchar();
Serial.print(mn);
Serial.print(". ");
Serial.print(inputString.substring(0,4));
c[0] = inputString.charAt(0);
c[1] = inputString.charAt(1);
c[2] = inputString.charAt(2);
c[3] = inputString.charAt(3);
c[4] = 0;
If so, change the below first
char *p, c[5], Z; /* p=pointer to c, c=user input, computer output, Z=recursion counter */
to
char *p, c1[5], c2[5], Z; /* p=pointer to c, c=user input, computer output, Z=recursion counter */
And next change the code that I pointed out
int r;
getserialchar();
Serial.print(mn);
Serial.print(". ");
c1[0] = inputString.charAt(0);
c1[1] = inputString.charAt(1);
c1[2] = 0;
c2[0] = inputString.charAt(2);
c2[1] = inputString.charAt(3);
c2[2] = 0;
1. e2e4 is a valid move (Fig-1) -- why do you want to separate it into these two parts: e2 and e4?
Figure-1:
int
main ()
const char *s = "e2e4";
char t [4];
char q [4];
sscanf (s, "%2s%2s", t, q);
printf (" %s %s\n", t, q);
To separate e2e4 into two parts (e2 and e4), you may include the following codes at the appropriate place of your sketch.
char initialPos[3];
char finalPos[3];
char myData[5];
byte n = Serial.available();
if(n == 4)
for(int i=0; i<4; i++)
myData[i] = Serial.read();
initialPos[0] = myData[0];
initialPos[1] = myData[1]; //char initialPos[] array holds e2
finalPos[0] = myData[2];
finalPos[1] = myData[3]; //char finalPos[] array holds e4
@GolamMostafa - you might want to force the 3rd byte to '\0' if initialPos and finalPos are not a global variables. better safe than sorry ![]()
J-M-L:
I have reserved 1-byte extra in the array in case the OP wants to print the content by inserting a null character.
I saw that, would have been probably good to mention as it seems OP is a beginner. hence my point.
J-M-L:
I always enjoy your interaction as it keeps me very inspired.![]()
You definitely have something in mind when you allocated 3 bytes instead of 2 that were needed - so felt good to explain what was in your mind (and ensure there was not this belief that everything is always zero initialized automagically)
GolamMostafa:
Figure-1:
hello i ant to separate the result b8c6
and send it to another arduino
sterretje:
Is it this piece of code? If not, point out where it is in your code.void loop() {
int r;
getserialchar();
Serial.print(mn);
Serial.print(". ");
c[4] = 0;
If so, change the below firstchar p, c[5], Z; / p=pointer to c, c=user input, computer output, Z=recursion counter */
tochar p, c1[5], c2[5], Z; / p=pointer to c, c=user input, computer output, Z=recursion counter */
And next change the code that I pointed outvoid loop() {
int r;
getserialchar();
Serial.print(mn);
Serial.print(". ");
c1[2] = 0;
c2[2] = 0;
sory i f you got me wrong but i want separate the output not the input.
in my project i mad another programe in another arduino to control a CNC to move the peace,
