Seperate Controller to control 8 relays
Hey guys,
I am new here and just started on an Arduino Project,
I need my Arduino to control 8 separate relays.
The relays I am using require 24 volts to activate.
I came across this chip
http://www.nxp.com/files/analog/doc/data_sheet/MC33298.pdf
It looks like it can do the job.
After doing more research it looks like the type of design is called an "H bridge", is this correct ?
So basically what I am asking is what chip could I use to control 8 separate relays by supplying them with 24 volts each also by using an SPI interface.
Byron
It looks like your chip is end of life. Is there a reason you want to use SPI? If not, there's a lot of examples on the web of using a transistor to drive a relay that you might use.
Well If I use that chip I will need less wires going to the Arduino board, I can use a transistor but ill need 8 of them and use 8 output pins on the board, I also need 8 other pins because Ill be taking current readings off plugs that the relays will be connected to.
The ship does not have to use an SPI interface.
Can anyone recommend a similar chip ?
If you are ok with using 8 i/o pins, then why not use a ULN2003 as a driver...
Data sheet
Oh come on! How much current do you need?
What about a TPIC6A595?
