I want to control two servos with an Arduino and some Python code on my computer. The Python program sends the angles (int between 0-180) for the Servos to the Arduino, encoded as bytes, with PySerial. The Arduino Code for just one Servo:
#include <Servo.h>
Servo servo1;
servo.attach(9);
while (Serial.available() > 0)
static unsigned int message_pos = 0;
char inByte = Serial.read();
if ( inByte != '\n' )
message[message_pos] = inByte;
message_pos++;
message[message_pos] = '\0';
int number = atoi(message);
servo.write1(number);
And the python code for one servo (not the actual one, just very simplified):
port = serial.Serial('COM9', 9600)
val = str(val) + '\n'
port.write(val)
Now, I want to control two servos at the same time, so I'd have to seperate the incoming serial data so that the arduino knows which servo to move to which position. I think using another termiantion charakter might work, right? But how do I do that?
There are several possibilities to solve your task.
Send always both values separated by a delimiter like a comma, colon or similar (first value servo1, second servo2) -> e.g. "99,50" or "180,10"
Just separate the data at the delimiter.
Send servo position separatly, each position marked by a header like "S1:" and "S2:" -> e.g. "S2:099" and "S1:000".
First you separate the header (example: "S1" and "S2") and the value ( example 99 and 0) then allocate the value in accordance with the header to servo1 or servo2.
For separating you can collect the incoming serial characters into a C string and use the C-string functions or use the String class and its methods.
