Now i see what i ve done , example 2 its garbage .
The code in example its not working either. i start to look around in the code for somme clues an i found
in ibusserial.cpp some sort of filter.
// only process messages we're interested in
if(source != 0x50 //MFL
&& source != 0x68 //RAD
&& source != 0x00 //gm
&& source != 0x18 //CDC
&& source != 0x6A //DSP
&& source != 0x44 //ews
&& source != 0x80 //ike
&& source != 0xC8 //TEL
&& source != 0xB0 //SES
&& source != 0xE8 //RLS
//lowercase are added by me .
The sketch complies but still no reaction when it supposed to happen .
This is what i was getting on Serialmonitor, before i made the adjustment in ibusserial.cpp, when lock button was pressed on the remote: DISCARDED: 00 04 BF 72 12 DB ( tested multiple times , 100% sure its the rite ibus message )
Remote_lock its defined in the library
const byte REMOTE_LOCK [6] PROGMEM = {
0x00 , 0x04 , 0xBF , 0x72 , 0x12 , 0xDB }; // Remote control lock PRESSED
This is the entire sketch.
// v0.1.0 - Beta branch
#include <avr/interrupt.h>
#include <IbusGlobals.h>
#include <IbusSerial.h>
#include <RingBuffer.h>
IbusSerial ibus; // Create an instance of the Ibus library called ibus.
// If using processor board with more than one HardwareSerial port, you don't need to use SoftwareSerial, or AltSoftSerial for
// DEBUG, so just define which HardwareSerial port you plan to use.
//#define debugSerial Serial2
// If using Arduino with only one hardware serial port (Uno, Nano etc) AND using MCP interface chip, use AltSoftSerial instead
// of SoftwareSerial for DEBUG messages. SoftwareSerial uses pin change interrrupts that clash with the Ibus library. Also note
// that AltSoftSerial only works on pins 8(Rx) & 9(Tx).
#include <AltSoftSerial.h>
AltSoftSerial debugSerial;
// Software serial can be used with Melexis interface chip, but not with Microchip MCP Lin bus transceiver chips.
//#include <SoftwareSerial.h>
//SoftwareSerial debugSerial(7, 8); // 7 is Rx, 8 is Tx
// Setting up our variables
boolean goodPacket; //boolean value set true if good IBUS message detected
byte source;
byte length;
byte *pDebugByte;
byte databytes[36]; // Byte array to store message data bytes. ibusByte array of 40 - 4 for (Source, length, destination, checksumByte) = 36
byte outgoingMsg[32];
int outgoingSize;
unsigned long currentTime;
ibus.setIbusSerial(Serial); // Tell library which serial port is used for IBUS. Must be HardwareSerial port.
ibus.setScrollSpeed(1500,1000,200,2); // Start delay, End delay, scroll speed & number of repeats. Defaults to 2000, 1000, 200, 2 if no alternatives specified
ibus.setIbusPacketHandler(packetHandler); // Define callback function. This is the function that is called by the library when it has a complete IBUS packet/message.
//ibus.sleepEnable(60); // Enable sleep timer, and set sleep time in seconds. Comment out/delete line to disable timer.
debugSerial.begin(9600); // Set debug Baud rate
ibus.setIbusDebug(debugSerial); // Tell library which serial port is used for DEBUG. Comment out line if debug disabled in IbusGlobals.h
debugSerial.println(F("--IBUS reader V2--"));
attachInterrupt(digitalPinToInterrupt(3), startTimer, CHANGE);
pinMode(13, OUTPUT);
ibus.run(); // This keeps the IbusSerial library running.
// This is where we compare the received message with all the message bytes
// in IbusGlobals.h, or to known source/destination, and respond accordingly.
// 2. Implement timer to remove written text from radio display after X seconds
void packetHandler(byte *packet) // callback function
source = packet[0];
length = packet[1];
byte destination = packet[2];
pDebugByte = packet;
// Identify message databytes - populate our databytes array
for (int i = 0, s = 3; i <= length - 3; i++, s++) {
databytes[i] = packet[s];
// react to unlock message form kline , testing only .
if(memcmp_P(packet, REMOTE_LOCK, 6) == 0 ) {
debugSerial.println(F("Remote control lock PRESSED"));
debugSerial.println(F("BAZINGA!"));
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
// Message from MFL_VOL_UP
if(memcmp_P(packet, MFL_VOL_UP, 6) == 0 ) {
// This is how to send text message to the Business CD/Radio display
ibus.radioWrite("Vol UP Vol UP Vol UP ");
// Message from MFL_VOL_DOWN
if(memcmp_P(packet, MFL_VOL_DOWN, 6) == 0 ) {
ibus.radioWrite("Vol DOWN");
// Message from RLS to LCM
if ((source == 0x00) && (destination == 0x04)){
if (databytes[3] == 0x11) {
debugSerial.println(F("It's dark out, lights commanded on"));
// TODO:
// Blinking alert LED wire will come into arduino as a digital input (Radar detector alert LED).
// Implement dimming feature here. If this I-Bus message is present, find a method to dim this LED
// Arduino output to actual LED == Increase resistance to ground? PWM? Or activate a relay that includes resistor?
void startTimer()
ibus.startTimer();
