sequencing analogRead
Please help! I need to get the following code to run sequentially... read, then on for 30 seconds and stop, read again, then on for 20 seconds and stop, read again, then on for 10 seconds and stop. then start again from the top.
It seems to me like it should work. It is doing what is described above, but in random order. I feel like I've tried everything to get it straight, but this is obviously not the case....
int ledPin = 13; // LED connected to digital pin 13
int analogPin = 3; // ir sensor connected to analog pin 3
int val = 0; // variable to store the read value
int threshold = 275; // threshold
pinMode(ledPin, OUTPUT); // sets the digital pin 13 as output
val = analogRead(analogPin); // read the input pin
if (val >= threshold)
digitalWrite(ledPin, HIGH); // sets the LED on
if (ledPin, HIGH)
delay(100); // waits for .1 second
digitalWrite(ledPin, LOW); // sets the LED off
delay(30000);
delay(100);
if (ledPin, HIGH)
delay(20000);
delay(100);
if (ledPin, HIGH)
delay(10000);
delay(100);
I think you are missing some "{" and "}"
after these statements :
if (ledPin, HIGH)
in each of the 3 main blocks
Thanks for responding. I've tried this sugestion and the program is still running in a random order. The only thing I've been able to do to get it to run sequentially is to get rid of all bet the beginning and end braces. But then it just works like a timer... 30 seconds on, twenty seconds off, ten seconds on, etc. It doesn't read the ir sensor at all.
Any other suggestions?
It would be easier to help if you could say a little more about what the sketch is supposed to do.
As writtne it looks like it will skip sequences if the val drops below the threshold for the analogRead. Is that what you want?
Does it work as expected if val is always greater than the threshold?
I'm checking out the function if the value is always greater thann the threshold now.
Here's what's happening...
I've hacked into the face of a CD player and am using the Arduino and it's led function to start/pause the cd. I'm trying to get it to run sequentially because I have audio tracks of different lengths. So, when the IR sensor detects someone, the cd player starts(ledpin HIGH), then pauses(led pin high) when the track is over, until the IR sensor is triggered again and continues playing the negt song, etc.
You are on point! If the the threshold is constantly >=, then it does work sequentially. I need ot to work this way all the time, whether someone is triggering it or not. can you help?
I think you've just learned an important lesson: before you start coding, write out a very clear and concise description of what your program will do, and how it will do it. Make sure that your description is rational and logical. Answer any questions that arise while you're analyzing your problem.
From your statements, I gather that your program should work something like this:
Input:
  • IR sensor connected to analogPin. When the sensor detects a person, analogPin will measure greater than threshold
Output:
  • ledpin going high triggers the CD player's "Play" button. (Why do you call it ledpin???)
CD:
  • contains 3 tracks: 30 seconds, 20 seconds, and 10 seconds
Operation:
When the IR sensor detects a person, it plays the next track in sequence. Timing is done by fixed delays.
At the end of each track, the program makes sure the person is gone. If necessary, it waits until the person is gone before proceeding.
==> Question: what happens after the third track has been played? How do you reset to the beginning? (At the moment, I'm just going to pretend that reset to the first track takes place by magic pixie dust. You can fix it later.)
Let's see what we can do to your code to make it comply with the program description.
//  CD Player
//    <add brief description of program operation here>
//  Program Constants:
#define threshold 275      // threshold
const int tracktime[] = {30,20,10};   //  Array of track times in seconds
                                      //  These are elements 0, 1, and 2
//  Input/Output:
#define ledPin 13          // LED connected to digital pin 13
#define analogPin 3        // ir sensor connected to analog pin 3
//  Start of code
  int tracknum = 0;   //  This will represent the current track number
  while(1)            //  Outer while loop for fastest loop repeat
    while( analogRead(analogPin) < threshold )  // wait for ir sensor to go high
    PushTheButton();               // start the track
    delay( tracktime[tracknum] );  // pause for track time
    PushTheButton();               // pause the track
    while( analogRead(analogPin) >= threshold )  // if the person is still near the
      delay(10);                                 // sensor, wait until person goes away
    if( ++tracknum > 2 )           // increment the track number.  If > 2, reset to zero
      tracknum = 0;
void PushTheButton()
  //  Punch the Play button for 100 milliseconds
  digitalWrite(ledpin,HIGH);
  delay(100);
  digitalWrite(ledpin,LOW);
Some program notes:
When you're defining fixed constants, such as pins and the threshold value, use the preprocessor #define, rather than an int declaration. You won't use extraneous memory locations, and you can't
change those values by mistake.
When using #define statements, note that there are no equal signs or semicolons.
When you must define constants in memory, as I did with the tracktime array, declare them as 'const'. If you then try to change them, the compiler will (properly) generate an error, reminding you of your logic bomb.
Don't declare a variable as global unless you absolutely need to. Note how I've declared tracknum in the loop() function. That's the only place we use that variable, so that's the only function that needs to know about it.
(Technically, we could have declared threshold and tracktime[] in loop(), but those are constants you'll use to tune the behavior of your program. It's nice to keep those things right up at the top where they're easy to find when you need to change them.)
In loop(), notice that I've built an outer while() endless loop that wraps the rest of your code. With the Arduino, the loop() function will also run as an endless loop, but there's a little delay, and possibly some other weirdness, that takes place before looping. Always play it safe and put your own endless loop structure in there to wrap your top level code.
while(1)
// your top level code goes here
In the other while() and if() calls, note that I can perform operations within the test parentheses:
This is a cleaner way of writing this stuff that, when you get used to reading it, is actually much easier to read and understand. On PICs, it also lets the compiler generate cleaner machine code. I presume the same holds for the Arduino's compiler.
Those two plus signs in front of tracknum are the pre-increment operator. The if expression means "increment tracknum. If it's greater than 2, do something..."
And finally, I've moved the Play button code to its own function to clean up the top level code.
Good luck!
Tom
GOOD GRIEF!
Talk about 'forest for the trees...' The previous version of your program that I posted would have paused 30, 20, and 10 milliseconds to play each CD track. Pop! Pop! Pop!
Here's a corrected version that will pause 30, 20, and 10 seconds:
//  CD Player
//  Input/Output:
//  Start of code
    delay_secs( tracktime[tracknum] );  // delay 'track time' seconds
      tracknum = 0;
void delay_secs( int secs )
  // delays 'secs' seconds
  int i;
  for(i=0; i<secs; i++)
  delay(100);
Sorry 'bout that, Chief!
Tom
