sequential circuit with d flip flop
my truth table for this circuit:
ABX|AB
000 00
001 01
010 01
011 10
100 10
101 11
110 11
111 00
my code:
//x=pin 8 and clk=pin 9, A=pin 6 and B=pin 7 clk=pin 2
int a,b,c,d,e,f,g,h,i,j,k,x; int A,B; int clk;
void setup(){ A=0; B=0;
pinMode(6,OUTPUT); pinMode(7, OUTPUT); digitalWrite(6,LOW); digitalWrite(7,LOW); //delay(3000); // attachInterrupt(0,clock,RISING);
void loop(){ x=digitalRead(8); // clk=digitalRead(9); a=NAND(b,c); b=NOR(d,d); c=NAND(x,g); d=NAND(e,f); e=NAND(A,h); f=NAND(A,!B); g=NAND(A,!B); h=NOR(x,x); i=NAND(h,B); j=NAND(x,!B); k=NAND(i,j); int lasttemp =0; int temp = digitalRead(9); // gets the clock pulse delay(50); if ( (temp != lasttemp) && (temp == 1) && clk!=1) { A=dff(a,clk,A); B=dff(k,clk,B); clk =1; } else if (digitalRead(9)==0)clk = 0; lasttemp=temp;
if(clk){
} digitalWrite(6,A); digitalWrite(7,B); }
int NAND(int x, int y){ if(x && y) return(0); else return(1); }
int NOR(int x, int y){ if(!x && !y) return(1); else return(0); }
int dff(int d, int clk, int memory){ if (clk==1) return(d); else return(memory); }
void clock(){ //int a,b,c,d,e,f,g,h,i,j,k,x; //clk=digitalRead(9); // x=digitalRead(8); /* int temp = digitalRead(9); // gets the clock pulse delay(50); if ( (temp != lasttemp) && (temp == 1) ) clk = 1; else clk = 0; lasttemp=temp;
you can probably see that I am attempting to fix the button bounce. I always have problems with my code in the A output especially the first 3 rows of the truth table. My question is can you fix my code to do what I want it to. I have played with the idea of button debounce and attachInterupt as well. I am at a loss, also I have been thinking that there is a problem with the rising edge of my switches, i don't understand how to fix this
if(clk){
What were you trying to accomplish here?
ortonjon: x=digitalRead(8);
I doubt you're going to be able to read a smiley face with much success. (This is what the CODE tags are there for).
ortonjon: can you fix my code to do what I want it to.
When is our assignment due by?
yeah sorry about the smilies and im not sure what you mean about when our assignment is due
ortonjon: yeah sorry about the smilies
Not sorry enough to fix it, though, I guess.
Rather than asking for help, you asked us to do the work. I just wanted to know when we had to do it by.
Go back to your first post. Hit the modify icon. Select the code, hit the # icon and then save it.
Why are you bothering to write all that logic simulation code? The whole thing is simply a look up table. Two lines of code at the most.
Unless as was said it is an assignment from a class that you want us to do for you.
Why the title? The question has nothing to do with a sequential circuit or a d type flip flop unless you are holding back on more stuff as well.
jon,
I know that you're trying to build a structural model of the circuit, but I realized that the behavioral model is fairly easy to build. I'll post the structural model in VHDL when I get the chance, but it may be a bit more work to model the circuit in C++.
/* Truth Table
    PS  | NS
    ABx | AB
    000 | 00
    001 | 01
    010 | 01
    011 | 10
    100 | 10
    101 | 11
    110 | 11
    111 | 00
// I/O Pins:
// clock input is interrupt0 on pin 2
#define x 3 // x input on pin 3
#define A 4 // Flip-Flop A output on pin 4
#define B 5 // Flip-Flop B output on pin 5
boolean flag(0);
byte AB (B00); // initialize output of ffa & ffb to zero
//B00 means binary 00, for example B0101 = 5
void setup(){
    pinMode(3,INPUT);  // x
    pinMode(4,OUTPUT); // A
    pinMode(5,OUTPUT); // B
    attachInterrupt(0,trigger,RISING);
void loop(){
/* Write the outputs for ffa & ffb
   using the value from AB: bit 0 holds the value for B
   and bit 1 holds the value for A
  digitalWrite(A,bitRead(AB,1));
  digitalWrite(B,bitRead(AB,0));
  if (flag) {
    delay(250); // delay to debounce the switch
    flag--;     // reset the trigger to catch the next clock
    if (digitalRead(3)==1) AB = ++AB % 4;
   no output changes unless x=1
   notice that the next state for AB is always
   one more than the current state, but never more than three
void trigger(){
// update the trigger
  if(!flag)flag++;
