Using code created by another person. The code works great except for the fact that it only makes two sequential data files then keeps re using the second file. Looks like the process is getting messed up in the storage of the last file name. it keeps appending the number instead of replacing the number.
Raw NMEA Logger for Arduino
Copyright (c) 2017 by Tak Yanagida (OnTarget Inc.)
This software is released under the MIT License.
#include <SPI.h>
#include <SD.h>
// Pin configurations
const uint8_t CARD_SELECT = 4;
const uint8_t SDCARD_LED = 8;
const uint8_t RED_LED = 13;
const uint8_t VBAT_PIN = A7;
// Other configurations
const float LIPO_LOWBAT_THRESHOLD = 3.55;
const unsigned long LOWBAT_CHECK_INTERVAL = 60000; // in millis
const unsigned long LOWBAT_BLINK_INTERVAL = 500;
const unsigned long SD_FLUSH_INTERVAL = 1000;
const unsigned long STATUS_REPORT_INTERVAL = 10000;
const char* const FILE_PREFIX = "AA"; // you can change this to distinguish multiple loggers
const char* const FILE_EXT = ".txt";
const char* const LASTNUM_FILE = "LASTNUM.txt";
const int FILENUM_LEN = 6;
const char* const INITIAL_NUM = "000000";
const char* const DEFAULT_NUM = "999999";
// global variables
File logfile;
unsigned long num_lines;
struct {
bool lowbat = false;
} global_status;
// blink out an error code
void error(uint8_t errno) {
while (1) {
uint8_t i;
for (i = 0; i < errno; i++) {
digitalWrite(RED_LED, HIGH);
delay(100);
digitalWrite(RED_LED, LOW);
delay(100);
for (i = errno; i < 10; i++) {
delay(200);
void read_nmea_and_log() {
static unsigned long last_sd_flush_millis = 0;
unsigned long current_millis;
while (Serial1.available()) {
char c = Serial1.read();
logfile.print(c);
if (c == '\n') {
num_lines++;
Serial.print("LINES: ");
Serial.println(num_lines);
current_millis = millis();
if (current_millis < last_sd_flush_millis + SD_FLUSH_INTERVAL) {
continue;
digitalWrite(SDCARD_LED, HIGH);
logfile.flush();
last_sd_flush_millis = current_millis;
digitalWrite(SDCARD_LED, LOW);
void check_battery() {
float vbat = analogRead(VBAT_PIN) * 2 * 3.3 / 1024;
Serial.print("VBat: ");
Serial.println(vbat);
if (vbat < LIPO_LOWBAT_THRESHOLD) {
global_status.lowbat = true;
void show_global_status() {
static int red_led_state = LOW;
static unsigned long last_blink_millis = 0;
static unsigned long last_status_reported_millis = 0;
unsigned long current_millis = millis();
if (current_millis > last_status_reported_millis + STATUS_REPORT_INTERVAL) {
Serial.print("lowbat: ");
Serial.println(global_status.lowbat);
last_status_reported_millis = current_millis;
if (global_status.lowbat) {
if (current_millis > last_blink_millis + LOWBAT_BLINK_INTERVAL) {
if (red_led_state == LOW) {
red_led_state = HIGH;
digitalWrite(RED_LED, red_led_state);
last_blink_millis = current_millis;
void gen_filename(char* new_filename)
File lastnum_file;
char new_filenum[FILENUM_LEN];
lastnum_file = SD.open(LASTNUM_FILE, FILE_READ);
if (!lastnum_file) {
strcpy(new_filenum, INITIAL_NUM);
goto save_filenum;
lastnum_file.seek(0);
lastnum_file.read(new_filenum, FILENUM_LEN);
for (int i = 0; i < FILENUM_LEN; i++) {
if (!isDigit(new_filenum[i])) {
strcpy(new_filenum, DEFAULT_NUM);
lastnum_file.close();
goto save_filenum;
// increment new_filenum only when successfully read from file
int i = FILENUM_LEN - 1;
while (++new_filenum[i] > '9') {
new_filenum[i] = '0';
if (--i < 0) {
save_filenum:
lastnum_file = SD.open(LASTNUM_FILE, FILE_WRITE);
lastnum_file.print(new_filenum);
strcpy(new_filename, FILE_PREFIX);
strcat(new_filename, new_filenum);
strcat(new_filename, FILE_EXT);
return;
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
Serial.println("\r\nGPS logger start");
pinMode(RED_LED, OUTPUT);
// initialize GPS module
Serial1.begin(9600);
num_lines = 0;
// see if the card is present and can be initialized
if (!SD.begin(CARD_SELECT)) {
Serial.println("Card init. failed!");
error(2);
char filename[15];
gen_filename(filename);
logfile = SD.open(filename, FILE_WRITE);
if (!logfile) {
Serial.print("Couldn't create ");
Serial.println(filename);
error(3);
Serial.print("Writing to ");
// LED configuration
pinMode(SDCARD_LED, OUTPUT);
Serial.println("Ready!");
// initialize MTK3339
const char* nmea_init_sentences[] = {
"$PMTK314,0,1,0,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28", // change NMEA sentence frequency
"$PMTK401*37", // PMTK_API_Q_DGPS_ENABLED
"$PMTK413*34", // PMTK_API_Q_SBAS_ENABLED
"$PMTK414*33", // PMTK_API_Q_NMEA_OUTPUT
"$PMTK419*3E", // PMTK_API_Q_SBAS_MODE
"$PMTK605*31", // PMTK_Q_RELEASE
"$PMTK607*33", // PMTK_Q_EPO_INFO
"$PMTK447*35", // PMTK_Q_Nav_Threshold
"$PMTK430*35", // PMTK_API_Q_DATUM
NULL
for (int i = 0; nmea_init_sentences[i]; i++) {
Serial1.println(nmea_init_sentences[i]);
read_nmea_and_log();
static unsigned long last_lowbat_check_millis = 0;
show_global_status();
delay(30000);
if (millis() > last_lowbat_check_millis + LOWBAT_CHECK_INTERVAL) {
check_battery();
last_lowbat_check_millis = current_millis;
original source comes from GitHub - takyanagida/raw_nmea_logger: Raw NMEA Logger for Arduino and Developing GPS Logger with SD Card Slot
Thanks for any help with this minor code challenge
