I'm working on a project for school where I am simulating sequential tail lights with a breadboard and LEDs. I'm using an IR remote to control the functions of the lights. So far I am able to control the lights that only need to turn on and off. The issue I'm having is with the sequential turn signals. When I press the "turn signal" it creates a while loop to keep the turn signal going, but it gets stuck inside of the loop. I need help figuring out how to stop the loop and turn the lights off when I press the same button or a separate "off" button. I am also not able to control any other lights when it gets stuck inside of this loop. So for example when the turn signals are on maybe the brake lights need to turn on and off.
Code
#include <IRremote.h> //including infrared remote header file
int RECV_PIN = 53; // the pin where you connect the output pin of IR sensor
IRrecv irrecv(RECV_PIN);
decode_results results;
int Red1 = 13;
int Red2 = 10;
int Red3 = 7;
int Red4 = 4;
int Red5 = 16;
int Red6 = 19;
int Red7 = 22;
int Red8 = 25;
int Red9 = 11;
int Red10 = 8;
int Red11 = 5;
int Red12 = 2;
int Red13 = 17;
int Red14 = 20;
int Red15 = 23;
int Red16 = 26;
int Yellow1 = 12;
int Yellow2 = 9;
int Yellow3 = 6;
int Yellow4 = 3;
int Yellow5 = 28;
int Yellow6 = 15;
int Yellow7 = 18;
int Yellow8 = 21;
int Yellow9 = 24;
int Yellow10 = 27;
int White1 = 29;
int White2 = 14;
int LedOn[] = {0,0,0,0,0};
#define ButtonR 0XFFFFFFFF
#define Button0 0xFF6897
#define Button1 0xFF30CF
#define Button2 0xFF18E7
#define Button3 0xFF7A85
#define Button4 0xFF10EF
#define Button5 0xFF38C7
#define Button6 0xFF5AA5
#define Button7 0xFF42BD
#define Button8 0xFF4AB5
#define Button9 0xFF52AD
#define ButtonP 0xFFA25D
#define ButtonPrev 0xFF22DD
#define ButtonFwd 0xFFC23D
#define ButtonPlay 0xFF02FD
#define ButtonVol_Up 0xFF629D
#define ButtonVol_D 0xFFA857
#define ButtonDown 0xFFE01F
#define ButtonUp 0xFF906F
#define ButtonEQ 0xFF9867
irrecv.enableIRIn();
pinMode (Red1, OUTPUT);
pinMode (Red2, OUTPUT);
pinMode (Red3, OUTPUT);
pinMode (Red4, OUTPUT);
pinMode (Red5, OUTPUT);
pinMode (Red6, OUTPUT);
pinMode (Red7, OUTPUT);
pinMode (Red8, OUTPUT);
pinMode (Red9, OUTPUT);
pinMode (Red10, OUTPUT);
pinMode (Red11, OUTPUT);
pinMode (Red12, OUTPUT);
pinMode (Red13, OUTPUT);
pinMode (Red14, OUTPUT);
pinMode (Red15, OUTPUT);
pinMode (Red16, OUTPUT);
pinMode (Yellow1, OUTPUT);
pinMode (Yellow2, OUTPUT);
pinMode (Yellow3, OUTPUT);
pinMode (Yellow4, OUTPUT);
pinMode (Yellow5, OUTPUT);
pinMode (Yellow6, OUTPUT);
pinMode (Yellow7, OUTPUT);
pinMode (Yellow8, OUTPUT);
pinMode (Yellow9, OUTPUT);
pinMode (Yellow10, OUTPUT);
pinMode (White1, OUTPUT);
pinMode (White2, OUTPUT);
if (irrecv.decode(&results)){
int value = results.value;
irrecv.resume();
switch(results.value) {
// Brakes On/Off
case ButtonVol_Up :
if (LedOn[1] == 1) {
digitalWrite(Red1, LOW);
digitalWrite(Red2, LOW);
digitalWrite(Red3, LOW);
digitalWrite(Red4, LOW);
digitalWrite(Red5, LOW);
digitalWrite(Red6, LOW);
digitalWrite(Red7, LOW);
digitalWrite(Red8, LOW);
LedOn[1] = 0;
digitalWrite(Red1, HIGH);
digitalWrite(Red2, HIGH);
digitalWrite(Red3, HIGH);
digitalWrite(Red4, HIGH);
digitalWrite(Red5, HIGH);
digitalWrite(Red6, HIGH);
digitalWrite(Red7, HIGH);
digitalWrite(Red8, HIGH);
LedOn[1] = 1;
// Running Lights On/Off
case ButtonVol_D :
if (LedOn[2] == 1) {
digitalWrite(Red9, LOW);
digitalWrite(Red10, LOW);
digitalWrite(Red11, LOW);
digitalWrite(Red12, LOW);
digitalWrite(Red13, LOW);
digitalWrite(Red14, LOW);
digitalWrite(Red15, LOW);
digitalWrite(Red16, LOW);
LedOn[2] = 0;
digitalWrite(Red9, HIGH);
digitalWrite(Red10, HIGH);
digitalWrite(Red11, HIGH);
digitalWrite(Red12, HIGH);
digitalWrite(Red13, HIGH);
digitalWrite(Red14, HIGH);
digitalWrite(Red15, HIGH);
digitalWrite(Red16, HIGH);
LedOn[2] = 1;
// Left Turn Signal On
case ButtonPrev :
while (results.value != ButtonDown){
digitalWrite(Yellow5, HIGH);
delay(300);
digitalWrite(Yellow4, HIGH);
delay(300);
digitalWrite(Yellow3, HIGH);
delay(300);
digitalWrite(Yellow2, HIGH);
delay(300);
digitalWrite(Yellow1, HIGH);
delay(300);
digitalWrite(Yellow5, LOW);
delay(300);
digitalWrite(Yellow4, LOW);
delay(300);
digitalWrite(Yellow3, LOW);
delay(300);
digitalWrite(Yellow2, LOW);
delay(300);
digitalWrite(Yellow1, LOW);
// Left Turn Signal Off
case ButtonDown :
