Serial ~500ms delay in remote controlled car project using bluetooth
Hello everyone,
I have an annoying problem with my remote controlled car project. Any signal I send via bluetooth has a delay of about 500ms which can get really annoying when trying to control the car. I made a small android app which acts as the remote control. I tested the app already to check if the error might be there but the bluetooth signal is sent out immediatelly from the phone.
Apart from that everything works perfectly.
I have absolutely no idea why it takes half a second to read the serial data. I've done some projects using the hc-06 on a raspberry pi and the data was received immediately.
Parts used in the project:
  • Arduino Mega
  • 8x 1.5V Batteries
  • 2x geared DC motors
  • 1x L293D
  • 1x HC-06 Bluetooth slave
Thanks to anyone who is taking their time to try and help me. There is a bit of code below...
Picture of the car: (The breadboard is just temporary until I finish it 100%) |500x281
RC_Car.ino
#include "Car.h"
Car* pCar;
    Serial1.begin(115200);
    pCar = new Car(2, 3, 4, 5);
    pCar->update();
Car.h
#ifndef CAR_H
#define CAR_H
#define BT_REGISTER "hi"
#define BT_FORWARD  "fwd"
#define BT_BACKWARD "bwd"
#define BT_LEFT     "lft"
#define BT_RIGHT    "rgt"
#define BT_STOP     "stp"
#define BT_SPEED    "spd"
#define DISCONNECTED_LED_PIN    22
#define CONNECTED_LED_PIN       24
#include "MotorControl.h"
class Car
    private:
        MotorControl _m1;
        MotorControl _m2;
        int _speed;
        bool _connected;
        void update_controls();
    public:
        Car(int m1_pin_fwd, int m1_pin_bwd, int m2_pin_fwd, int m2_pin_bwd);
        void update();
#endif
Car.cpp
#include "Car.h"
#include "Arduino.h"
Car::Car(int m1_pin_fwd, int m1_pin_bwd, int m2_pin_fwd, int m2_pin_bwd)
    : _m1(m1_pin_fwd, m1_pin_bwd),
      _m2(m2_pin_fwd, m2_pin_bwd)
    _connected = false;
    _m1.speed(255);
    _m2.speed(255);
    pinMode(DISCONNECTED_LED_PIN, OUTPUT);
    pinMode(CONNECTED_LED_PIN, OUTPUT);
    digitalWrite(DISCONNECTED_LED_PIN, HIGH);
    digitalWrite(CONNECTED_LED_PIN, LOW);
void Car::update()
    if (_connected)
        update_controls();
        if (Serial1.available() > 0)
            String data = Serial1.readString();
            if (data == "hi")
                _connected = true;
                digitalWrite(DISCONNECTED_LED_PIN, LOW);
                digitalWrite(CONNECTED_LED_PIN, HIGH);
void Car::update_controls()
        /*if (data.startsWith(BT_SPEED))
            // TODO
        else*/ if (data == BT_FORWARD)
            _m1.forward();
            _m2.forward();
        else if (data == BT_BACKWARD)
            _m1.backward();
            _m2.backward();
        else if (data == BT_LEFT)
            _m1.forward();
            _m2.backward();
        else if (data == BT_RIGHT)
            _m1.backward();
            _m2.forward();
        else if (data == BT_STOP)
            _m1.stop();
            _m2.stop();
MotorControl.h
#ifndef MOTOR_CONTROL_H
#define MOTOR_CONTROL_H
enum MotorMode
    MOTOR_FORWARD,
    MOTOR_BACKWARD,
    MOTOR_STOP
class MotorControl
    private:
        int _pin_fwd;
        int _pin_bwd;
        int _speed;
        MotorMode _mode;
    public:
        MotorControl(int pin_fwd, int pin_bwd);
        void forward();
        void backward();
        void stop();
        void speed(int speed);
#endif
MotorControl.cpp
MotorControl::MotorControl(int pin_fwd, int pin_bwd)
    _pin_fwd = pin_fwd;
    _pin_bwd = pin_bwd;
    _speed = 0;
    _mode = MOTOR_STOP;
    pinMode(_pin_fwd, OUTPUT);
    pinMode(_pin_bwd, OUTPUT);
    analogWrite(_pin_fwd, 0);
    analogWrite(_pin_bwd, 0);
void MotorControl::forward()
    _mode = MOTOR_FORWARD;
    analogWrite(_pin_fwd, _speed);
void MotorControl::backward()
    _mode = MOTOR_BACKWARD;
    analogWrite(_pin_bwd, _speed);
void MotorControl::stop()
    _mode = MOTOR_STOP;
void MotorControl::speed(int speed)
    _speed = speed;
    switch (_mode)
        case MOTOR_FORWARD:
        case MOTOR_BACKWARD:
Connect bluetooth module to a computer through a serial adapter, set it up (if needed) manually over serial monitor, and see if there's a delay then.
Nathema: Any signal I send via bluetooth has a delay of about 500ms which can get really annoying when trying to control the car.
You are reading your command strings with a default timeout of ONE SECOND:
How did you manage to find such a silly and slow working function, while you want fast communication?
Hint: If your total communication is existing of only a few different commands, you don't need to send 'strings', but a single character would be enough as a single command. So perhaps transmit a single 'char' as a command, and not a "string".
Perhaps:
#define BT_REGISTER 'h'
#define BT_FORWARD 'f'
#define BT_BACKWARD 'b'
#define BT_LEFT 'l'
#define BT_RIGHT 'r'
#define BT_STOP 's'
#define BT_SPEED1 '1'
#define BT_SPEED2 '2'
#define BT_SPEED3 '3'
#define BT_SPEED4 '4'
#define BT_SPEED5 '5'
And then receive and compare single characters:
char data = Serial1.read();
I admire @jurs patience in finding that in your several chunks of code.
The examples in serial input basics are simple reliable non-blocking ways to receive input. One of them should be suitable.
...R
Holy fuck I'm stupid.
Thanks guys, it's working perfectly now.
