Serial and array question
Hello folks,
I'm a new user to the Arduino, so far really enjoying using it. I've run through some of the tutorials, and am now trying to piece together a program.
I am trying to communicate with a device which sends 9 characters, of those 9 I am interested in the 5th value. For right now I am reading the entire string into an array, declaring the 5th value in the array as a different variable and lighting some LEDs from there.
My questions are :
  1. Can I use the serial monitor while my program is also reading a serial value on pin 1?
  2. So far I can't get any change out of the LEDs, I am unsure if it is because I am not filling the array properly, or if I am accessing improperly. Could you fine folks comment on my code?
int ledPin = 8;
int ledPinLow = 7;
int IncomArray[9];
int TensDigit = 0;
    Serial.begin(300);
    pinMode(ledPin, OUTPUT);
    pinMode(ledPinLow, OUTPUT);
    Serial.flush();
void loop(){
  while (Serial.available() >= 9) { // Wait 'till there are 9 Bytes waiting
for(int n=0; n<9; n++)
   IncomArray[n] = Serial.read(); // Then: Get them.
IncomArray[5] = TensDigit; // Fill Tens digit place with value in IncomArray position 5
if(TensDigit >= 5){ // If the tens digit is equal to 5,
  digitalWrite(ledPin, HIGH);   // set the LED on
  delay(1000);  // Wait one second
Serial.flush();   // Flush buffer
if(TensDigit < 5){ // If tens digit is less than 5,
  digitalWrite(ledPinLow, HIGH); // Turn on ledPinLow
Haven't you got this assignment the wrong way round?
Indeed I do!
However even when reversed I'm still not getting a change.
The index value for the 5th item in the array is 4, not 5.
Also, value in the array is not the digit. It is the ascii value of the digit. You need to subtract '0' from the ascii value to get the digit.
Thank you Groove and PaulS, I've modified the line as follows.
TensDigit = (IncomArray[5] - '0') ; // Fill Tens digit place, subtract ascii '0' to convert digit to usable form
I'm interested in array position 5, 6th position. I think my wording was just off.
I'll be trying it out shortly! Thanks again!
Making progress! I've made some modifications and am able to receive my serial values. However the values that I am seeing are not what I expected. I have modified my code to be:
char Value[9];  // Initialize array for values
int TensDigit;  // First digit in the tens place
int OnesDigit; // Second digit in the ones place
int DecimalDigit; // Decimal Digit
int LEDpin = 13; // Alarm LED
void setup(){
  Serial.begin(300);      //Start serial to device
  pinMode(LEDpin, OUTPUT);    // define LEDpin as an output
void loop(){
while (Serial.available()>8) { // Wait 'till there are 9 Bytes waiting
Serial.println("Serial is working"); // Let me know that the serial is available
for(int n=0; n<9; n++){
   Value[n] = Serial.read(); // Loop iterates until each spot is filled
Serial.flush(); //Clear buffer after reading values, EM noise etc.
 TensDigit = Value[5] - '0';  // Tens digit in array Value subtracted from '0' to give a usable integer
 OnesDigit = Value[6] - '0'; // Ones digit in array Value subtracted from '0' to give a usable integer
 DecimalDigit = Value[7] - '0'; // Decimal digit in array Value subtracted from '0' to give a usable integer
  Serial.println(Value); // Print entire value array
  Serial.println(TensDigit); // Print the integer value in TensDigit
  Serial.println(OnesDigit); // Print the integer value in OnesDigit
  Serial.println(DecimalDigit); // Prints the integer value in DecimalDigit
  if(TensDigit >= 5)  // If the integer in TensDigit is greater than or equal to five:
    digitalWrite(LEDpin, HIGH); // Turn on the LED
    else // If not:
      digitalWrite(LEDpin, LOW); // Turn it off
delay(1000); // Wait one second and repeat (Neccessary?)
I am watching it using the serial monitor and I get my verification that the serial is working, but the array returns :
ÓÛÛÛ<~w¿
The expected return should be a numerical string... Can anyone offer some insight?
I am attempting to communicate with a hardness testing head, the expected format for my arrayed values is:
0 = Start
1 = Sequence 0
2 = Sequence 1
3 = Sequence 2
4 = Blank
5 = Tens Digit
6 = Ones Digit
7 = Decimal Digit
8 = Tolerance
9 = Carriage return
Value is an array of characters. It is not a string. This will not work.
The difference between an array of characters and a string is that a string is an array of characters that is NULL terminated. You don't even have room for the NULL terminator in the array.
I think you should change this:
to this:
  Serial.print("Complete value: [");
  Serial.print(Value); // Print entire value array
  Serial.println("]");
  Serial.print("Tens digit: [");
  Serial.print("Ones digit: [");
  Serial.print("Decimal digit: [");
This makes it easier to see what data is being sent back (in)correctly.
It is not a string, but assuming ASCII characters were input, then it should have echoed something legible.
I agree. But, there may have been control characters that moved the cursor around, resulting in the legible data being overwritten. We can't see how much data was output. There were 4 lines that should have been printed, but OP only showed one line, and didn't say which line that was.
I amended the program, still had issues and decided to investigate other issues. The manufacturer pinout that was provided has proven to be incorrect, once I located the proper pins I am now receiving values that make sense! Though they are not in the expected format as defined by the manufacturer. (Surprise!)
I am receiving :
Complete value: [ 0: D 54.5
Tens digit: [5]
Ones digit: [4]
Decimal digit: [5]
I have changed my code to use array positions 10, 11 and 13 to display digits so that portion works like a charm.
I can now see that it is fragile, and if a perfect string isn't received it won't behave as expected. I extended the array to see if anything else is after my decimal digit, but all I receive is :ÿÿÿÿÿÿÿÿÿÿ
for the remainder of the array regardless of size.
I am quite pleased so far that I am receiving what I want, but I am at a loss on how to ensure that the data format as I see it above is displayed properly.
Could you offer any insight?
I've been looking at this http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1271794997 and was wondering if something like below. Would I modify it to work so that it expects a character count? Or is there a better way to check for an end?
CharIn = '\0';
while(Serial.available() > 0 && CharIn != FOOTER && i<INPUT_MAX_LENGTH-1)
   CharIn = Serial.read();
   StringIn[i++] = CharIn;
   StringIn[i] = '\0'; // Append a NULL so the string is NULL terminated
Thanks again folks!
