Serial and RFID - Comms
Hello,
I got a arduino UNO and a RFID Module for Xmas.
I can set the RFID Module in to read mode and can also send a standby command.
I am now trying to get my code to read the ID from the Tag and Print to Serial all on one line.
This is what I have do so far.
#include <SoftwareSerial.h> //Include softSerial in the project
SoftwareSerial mySerial(10, 11); //softSerial rx, tx Pins
int incomingByte = 0;  //incoming serial data
  //Start Hardware serial comms
  //start software comms
  mySerial.begin(9600);
  //Send HEX command to mySerial
  int inByte = Serial.read();
  switch (inByte){
    case 'r':
    Serial.println("Auto read card Enabled");
    mySerial.write(0x02);
    case 'p':
    Serial.println("Standby Mode Enabled");
    mySerial.write(0xab);  //Not sure if there is a better way to send this all at once?
    mySerial.write(0x02);  //Not sure if there is a better way to send this all at once?
    mySerial.write(0x10);  //Not sure if there is a better way to send this all at once?
  //Send data only when received data
  if (mySerial.available()) {
    //Read the incomming byte:
    incomingByte = mySerial.read();
    //Send what come from mySerial to serial
      Serial.print(incomingByte, HEX);
  delay(100);
This is what I get in Serial with this code.
ac
d0
2 <- Should be 02, but shows it as only 2?? Same with other ID's that start with a 0
4a
I want it to read -> acd0024a then a new line.
I think I need to do something with "if (mySerial.available())" like <4 or >4. I'me not sure, Also a buffer flush?
This is the RFID module -> http://www.ebay.co.uk/itm/140642657638
Any help would be much appreciated.
--Mick--
Serial.print(integer) does not print leading zeroes. If you want them you have to insert them yourself:
if (value < 16)
    Serial.print("0");
Serial.print(value, HEX);
Checking for 3 or more characters in the input buffer is a good idea:
    if (mySerial.available > 2)
        result[0] = mySerial.read();
        result[1] = mySerial.read();
        result[2] = mySerial.read();
I documented an RFID system here:
It's even better when you remember the ()s.
    if (mySerial.available() > 2)
