I have a problem I can't solve for a some time now so maybe you can help me.
I am working on a car display mounted inside of the steering wheel. Display consists of a few 74hc595 registers attached to LED lights and 8seg displays. Arduino Nano v3 is used to control them. Data is fed to it via serial link by another Arduino which is used to collect data from the engine control unit (ECU).
So where is the problem? Well, everything was working just fine but all of the sudden display stopped working. It has power but communication between the two Arduinos gives me the headaches.
Why? Because if I connect laptop to the Nano in the steering wheel I can send command words to it and display lights up as it should. Also I am receiving correct data which is sent by Arduino reading data from the ECU. It makes no sense to me.
Ground levels are the same and I obviously have same serial settings. So what might be wrong?
