Hello everyone,
During working on my project, I faced a problem with controlling stepper motors...
A brief introduction
Arduino mega is receiving data (0 or 1) from Kinect via processing for activation each of eight stepper motors. When stepper gets 1, it has to rotate to a certain number of steps(15000), and then, if 1 changes to 0 - it turns to an initial position.
In this way, all steppers should be able to rotate simultaneously, but independently. And this is my stumbling block. I need to have a non-blocking code, but at the same time steppers should reach 15000 steps once they get 1.
Message from Processing has eight integers and consist of seven 0 and one 1.
I have tried AccelStepper library, but did not succeed. Whether motors are moving slowly and unevenly or continuously and blocking the code.
Steppers - 42BYGHW609
Drivers - a4988
If you have any ideas, I would appreciate any help
Here is my arduino code:
#include <AccelStepper.h>
AccelStepper stepper1(1,22,23);
AccelStepper stepper2(1,24,25);
AccelStepper stepper3(1,26,27);
AccelStepper stepper4(1,28,29);
AccelStepper stepper5(1,30,31);
AccelStepper stepper6(1,32,33);
AccelStepper stepper7(1,34,35);
AccelStepper stepper8(1,36,37);
char HEADER = 'H';
char A_TAG = 'M';
int TOTAL_BYTES = 8; // the total bytes in a message
//data variables
int oldA,oldB,oldC,oldD,oldE,oldF,oldG,oldH,oldK = 0; //Storing previous value
int a,b,c,d,e,f,g,h,k = 0;
void setup(){
stepper1.setMaxSpeed(500);
stepper2.setMaxSpeed(500);
stepper3.setMaxSpeed(500);
stepper4.setMaxSpeed(500);
stepper5.setMaxSpeed(500);
stepper6.setMaxSpeed(500);
stepper7.setMaxSpeed(500);
stepper8.setMaxSpeed(500);
void loop(){
//Reading data from Kinect
char tag;
if ( Serial.available() >= TOTAL_BYTES)
if( Serial.read() == HEADER)
tag = Serial.read();
if(tag == A_TAG)
//Collect integers
a = Serial.read();
b = Serial.read();
c = Serial.read();
d = Serial.read();
e = Serial.read();
f = Serial.read();
g = Serial.read();
h = Serial.read();
k = Serial.read();
Serial.print("Received integers | a:");
Serial.print(a);
Serial.print(", b:");
Serial.print(b);
Serial.print(", c:");
Serial.print(c);
Serial.print(", d:");
Serial.print(d);
Serial.print(", e:");
Serial.print(e);
Serial.print(", f:");
Serial.print(f);
Serial.print(", g:");
Serial.print(g);
Serial.print(", h:");
Serial.print(h);
Serial.print(", k:");
Serial.println(k);
Serial.print("got message with unknown tag ");
Serial.write(tag);
if(a > oldA){
stepper1.moveTo(15000);
stepper1.run();
if(a < oldA){
stepper1.moveTo(0);
stepper1.run();
if(b > oldB){
stepper2.moveTo(15000);
stepper2.run();
if(b < oldB){
stepper2.moveTo(0);
stepper2.run();
if(c > oldC){
stepper3.moveTo(15000);
stepper3.run();
if(c < oldC){
stepper3.moveTo(0);
stepper3.run();
if(d > oldD){
stepper4.moveTo(15000);
stepper4.run();
if(d < oldD){
stepper4.moveTo(0);
stepper4.run();
if(f > oldF){
stepper5.moveTo(15000);
stepper5.run();
if(f < oldF){
stepper5.moveTo(0);
stepper5.run();
if(g > oldG){
stepper6.moveTo(15000);
stepper6.run();
if(g < oldG){
stepper6.moveTo(0);
stepper6.run();
if(h > oldH){
stepper7.moveTo(15000);
stepper7.run();
if(h < oldH){
stepper7.moveTo(0);
stepper7.run();
if(k > oldK){
stepper8.moveTo(15000);
stepper8.run();
if(k < oldK){
stepper8.moveTo(0);
stepper8.run();
//Updating previous value
oldA = a;
oldB = b;
oldC = c;
oldD = d;
oldF = f;
oldG = g;
oldH = h;
oldK = k;
