Serial.available() always returning 0 on ESP8266 ( Prodino WIFI)
I am using ProDINo WiFi ESP-WROOM V1.0
I am connecting to the device using an FTDI chip, I can read serial output from the prodino in the arduino serial monitor , however when I send any data through the serial monitor Serial.available() returns always 0. The TX pin on the FTDI chip blinks after I press send in the serial monitor, so I assume it is sending data correctly.
I have tried the same code on a Wemos D1 mini and it works with no issue
Here is the code:
void setup(void)
// You can open the Arduino IDE Serial Monitor window to see what the code is doing
// Serial connection from ESP-01 via 3.3v console cable
while (!Serial);
Serial.println(“Entering loop”);
  • @brief Main method.
  • @return void
    void loop(void)
    // send data only when you receive data:
    if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
// say what you got:
Serial.println(incomingByte, HEX);
Thanks and regards
Did you use a 3.3V version of the FTDI? If you use the default 5V version you may have damaged the RX pin of the ESP8266 which might be the cause of no reception.
