Serial.available() buffer reduced ??
i was using in arduino 022
while( Serial.available() < 127 );
but now the programm stalls at this point
but if i use
while( Serial.available() < 63 );
it continiues normanly
can we make it work again with 127???
thanks a lot
you can do that yourself:
goto - C:\Program Files (x86)\arduino-0022\hardware\arduino\cores\arduino -
edit HardwareSerial.cpp and search this code
#if (RAMEND < 1000)
#define RX_BUFFER_SIZE 32
#else
#define RX_BUFFER_SIZE 128
#endif
and change the 32 in 128 too …
thanks a lot it worked
Why are you not reading and storing the data as soon as it is available? What benefit is obtained by waiting until there is a truckload of data to process?
Or if you wanted to be portable, you could do
while( Serial.available() < RX_BUFFER_SIZE )
PaulS:
because then i want to send them over I2C
and because I2C is faster than Uart its not working
Which uses a 32 byte buffer. Makes sense.
The UART IS working, even when you aren't reading the data that it is buffering.
