Hi All!
I use serial.available + Fan button, but not working, until does not start lcdproc software in PC.
So: lcdproc+fan=WORK but do not run lcdproc software the Fan NOT work!
Where do I find the bug?
Thank you!
// Fan
int buttonPinH = 5;
int Fan = 6;
int counter = 0;
int stateButton = 0;
int buttonState = 0;
// LCD controller
#ifndef HD44780_LCDOBJECT
// hd44780 with hd44780_I2Cexp i/o class
#include <Wire.h>
#include <hd44780.h> // include hd44780 library header file
#include <hd44780ioClass/hd44780_I2Cexp.h> // i/o expander/backpack class
hd44780_I2Cexp lcd(0x20, I2Cexp_PCF8574, 4,5,6,0,1,2,3,7,LOW); // Electrofun & PNP transistor for BL
#define WIRECLOCK 400000
#endif
* Define your LCD parameters
* These must match what you configured in LCDd.conf on the linux host
#ifndef BAUDRATE
#define BAUDRATE 115200
#endif
#ifndef LCD_COLS
#define LCD_COLS 16
#endif
#ifndef LCD_ROWS
#define LCD_ROWS 2
#endif
void setup(){
SetupFan();
SetupLcdController();
void SetupFan(){
//Input or output?
pinMode(Fan, OUTPUT);
pinMode(buttonPinH, INPUT);
analogWrite(Fan, 80);
void SetupLcdController()
Serial.begin(BAUDRATE);
// set up the LCD's number of columns and columns:
lcd.begin(LCD_COLS, LCD_ROWS);
#ifdef WIRECLOCK
#if (ARDUINO > 10507) && !defined(MPIDE)
#endif
#endif
Wire.setClock(WIRECLOCK); // set i2c clock bit rate, if asked
// ------- Quick 3 blinks of backlight -------------
for(int i = 0; i< 3; i++)
lcd.backlight();
delay(250);
lcd.noBacklight();
delay(250);
lcd.backlight(); // finish with backlight on
// print out a banner that indicates lcd proc device
// and pramameters like baudrate and geometry
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Welcome!");
lcd.setCursor(0,1);
lcd.print("Multi Controller");
uint8_t serial_getch()
int incoming;
while (!Serial.available()){ }
// read the incoming byte:
incoming = Serial.read();
return (incoming & 0xff);
void loop(){
FanController();
LcdController();
void FanController(){
buttonState = digitalRead(buttonPinH);
if (buttonState == LOW)
counter++;
delay(100);
if(counter == 0)
else if(counter == 1)
digitalWrite(Fan,HIGH);
else {
counter =0;
void LcdController(){
uint8_t rxbyte;
rxbyte = serial_getch(); // Fetch byte
if(rxbyte==0xFE) // If command
lcd.command(serial_getch()); // Pass through raw hd44780 command
lcd.write(rxbyte); //Otherwise send it as text character
