Sorry for the large amount of code. I am trying the calibrate the brightness of neopixel LEDs using the serial port. The issue seems to be with line 46.
while(Serial.available()==0){}
every second or so program seems to escape the while loop and the following is printed to the terminal.
0: cycle light strips
1: cycle colour channel
7: decrease intensity
8: increase intensity
Side: Red: 10 Green: 10 Blue: 10
Ring: Red: 10 Green: 10 Blue: 10
Any suggestions on how I can fix this?
#include <FastLED.h>
#define NUM_LEDS_SIDE 90
#define NUM_LEDS_RING 40
#define NUM_LEDS_BASE 73
#define DATA_PIN_SIDE 53
#define DATA_PIN_RINGL 49
#define DATA_PIN_RINGR 45
#define DATA_PIN_BASE 41
CRGB LedsSide[NUM_LEDS_SIDE];
CRGB LedsRingL[NUM_LEDS_RING];
CRGB LedsRingR[NUM_LEDS_RING];
CRGB LedsBase[NUM_LEDS_BASE];
int r_base = 10;
int g_base = 10;
int b_base = 10;
int r_side = 10;
int g_side = 10;
int b_side = 10;
int r_ring = 10;
int g_ring = 10;
int b_ring = 10;
int target = 0;
int channel = 4;
int pointer = 0;
FastLED.addLeds<NEOPIXEL, DATA_PIN_RINGR>(LedsRingR, NUM_LEDS_RING);
FastLED.addLeds<NEOPIXEL, DATA_PIN_RINGL>(LedsRingL, NUM_LEDS_RING);
FastLED.addLeds<NEOPIXEL, DATA_PIN_SIDE>(LedsSide, NUM_LEDS_SIDE);
FastLED.addLeds<NEOPIXEL, DATA_PIN_BASE>(LedsBase, NUM_LEDS_BASE);
Serial.println("booting");
Serial.println("0: cycle light strips");
Serial.println("1: cycle color channel");
Serial.println("7: decrease intensity");
Serial.println("8: increase intensity");
void loop(){
target = Serial.parseInt();
while(Serial.available() > 0) {
char t = Serial.read();
if(target==0){
pointer++;
if(pointer==3){
pointer = 0;
if(target==1){
channel++;
if(channel==3){
channel = 0;
if(target==8&&pointer==0&&channel==0){r_base++;}
if(target==8&&pointer==0&&channel==1){g_base++;}
if(target==8&&pointer==0&&channel==2){b_base++;}
if(target==8&&pointer==1&&channel==0){r_side++;}
if(target==8&&pointer==1&&channel==1){g_side++;}
if(target==8&&pointer==1&&channel==2){b_side++;}
if(target==8&&pointer==2&&channel==0){r_ring++;}
if(target==8&&pointer==2&&channel==1){g_ring++;}
if(target==8&&pointer==2&&channel==2){b_ring++;}
if(target==7&&pointer==0&&channel==0){r_base--;}
if(target==7&&pointer==0&&channel==1){g_base--;}
if(target==7&&pointer==0&&channel==2){b_base--;}
if(target==7&&pointer==1&&channel==0){r_side--;}
if(target==7&&pointer==1&&channel==1){r_side--;}
if(target==7&&pointer==1&&channel==2){r_side--;}
if(target==7&&pointer==2&&channel==0){r_ring--;}
if(target==7&&pointer==2&&channel==1){g_ring--;}
if(target==7&&pointer==2&&channel==2){b_ring--;}
if(pointer = 0){print_colours(pointer,r_base,g_base,b_base);}
if(pointer = 1){print_colours(pointer,r_side,g_side,b_side);}
if(pointer = 2){print_colours(pointer,r_ring,g_ring,b_ring);}
for(int i = 0; i < NUM_LEDS_BASE; i++){LedsBase[i] = LedsBase[i].setRGB(r_base,g_base,b_base);}
for(int i = 0; i < NUM_LEDS_SIDE; i++){LedsSide[i] = LedsSide[i].setRGB(r_side,g_side,b_side);}
for(int i = 0; i < NUM_LEDS_RING; i++){LedsRingL[i] = LedsRingL[i].setRGB(r_ring,g_ring,b_ring);}
for(int i = 0; i < NUM_LEDS_RING; i++){LedsRingR[i] = LedsRingR[i].setRGB(r_ring,g_ring,b_ring);}
FastLED.show();
Serial.println(" ");
void print_colours(int pointer, int r,int g,int b){
if(pointer==0){Serial.print("Base:");}
if(pointer==1){Serial.print("Side:");}
if(pointer==2){Serial.print("Ring:");}
Serial.print(" Red: ");
Serial.print(r);
Serial.print(" Green: ");
Serial.print(g);
Serial.print(" Blue: ");
Serial.println(b);
