Serial.available is always 0 when using Serial.print
Hello guys,
Im facing the issue that Serial.available() is always 0 when I'm using Serial.print.
The search says it might be a known issue, but I do not found any solution that fits for me.
If I'm using the following simple code "serial receive buffer" supposed to have a value, right? Serial.print("Hello, World!"); does fill the buffer?
But Serial.available() is always 0? Do you know why?
Im using Arudino IDE 2.2.1 with ESP32C3.
  if (Serial.available() == 0) {
    // Will never be reached.
BR
Serial.available() returns the number of bytes in the receive buffer, not the send buffer
If you look at the value returned by Serial.print() it will tell you how many bytes were printed by the command
Serial.print fills the send buffer, but Serial.available checks for bytes in the receive buffer.
