I wrote a small Python program that sends strings over a USB connection. It is very simple:
#!/usr/bin/env python3
import argparse
import serial
parser = argparse.ArgumentParser(description='Send strings over USB')
parser.add_argument('--string', required=True, help='The string to send')
parser.add_argument('--port', required=False, help='USB port to use, defaults to /dev/ttyUSB0')
args = parser.parse_args()
cmd = vars(args)["string"]
port = vars(args)["port"]
if port is None or port == "":
port = "/dev/ttyUSB0"
ser = serial.serial_for_url(port, do_not_open=True)
ser.baudrate = 9600
ser.open()
if cmd is not None:
ser.write(str.encode(cmd))
ser.flush()
On my arduino, I have connected an RF24L01 tranceiver. I wrote a simple sketch that reads from serial input and then transmits whatever is read.
#include <RF24_config.h>
#include <RF24.h>
#include <nRF24L01.h>
#include <printf.h>
#include <SPI.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";
radio.begin();
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_MIN);
radio.stopListening();
pinMode(4, OUTPUT);
Serial.println("arduino ready ro recieve");
if (Serial.available()) {
digitalWrite(4, HIGH);
String command = Serial.readString();
char CMD[7];
command.toCharArray(CMD, sizeof(CMD));
radio.write(&CMD, sizeof(CMD));
This code works perfectly fine so long as I have the serial monitor window open. If the serial monitor window is not open, then the Serial.available() is never true. I have tested this by adding a led, and tried it on both an Uno and a Nano.
I am certain I must be missing something obvious. I would very much appreciate any help understanding what I am doing wrong, and why opening the serial monitor window would determine if my code works or not.
