Serial.available() problem
hi as you can see in the code i am trying to print a text in the serial monitor which is "b1/2e" but when try another text which is "c1/2e" i notice a space printed before "c" .
NOTE:i will be reseted to 0 every loop
if ( Serial.available()!=0)
str=Serial.read();
Serial.println(str);
my_data[i]=str;
i++;
if(str=='e')
l=1;
// Nombre de points
else if(str=='/')
coordonnees[i-1]=str;
nbr_slash++;
// Serial.println(nbr_slash);
// transformation en decimal
else if(str=='b'){}
else { coordonnees[i-1]=str-'0';}
Screenshot 2022-08-02 114240
then i tried to check the return of Serial.available() of each individual character
as you can see here even if nothing is going on serial input still Serial.available() returns 1
actually the Serial.available who is causing the space to appear because the array will be shifted by 1 any help why is this happening?
if ( Serial.available() >0 )
Serial.print(Serial.available());
str=Serial.read();
my_data[i]=str;
i++;
if(str=='e')
l=1;
// Nombre de points
else if(str=='/')
nbr_slash++;
else if(str=='b'){}
Use the edit function :pencil2: to put your code in code tags <|>. Read the post on how to get the most out of this forum which Is the top of every section
Or a space or newline printed after the "e"?
Do you terminate each input by "Enter"?
no i entered the full text at once
it is not a answer for question "Do you terminate your input by "Enter"?"
It works fine for me when I set the Serial Monitor line ending to "No line ending":
b
1
2
e
c
1
2
e
I had to guess at the variables you didn't declare but it compiles without warnings:
char str;
char my_data[80];
int i = 0;
int nbr_slash = 0;
int l;
int coordonnees[80];
  delay(200);
  if (Serial.available() != 0)
    str = Serial.read();
    my_data[i] = str;
    i++;
    if (str == 'e')
      l = 1;
    // Nombre de points
    else if (str == '/')
      coordonnees[i - 1] = str;
      nbr_slash++;
    else if (str == 'b')
      coordonnees[i - 1] = str - '0';
when i write "b1/2e" press enter then write "c1/2e"
Is the extra character on the end of the first entry or the start of the second entry ?
Print ">" before each character and "<" after it and you will be able to tell
What is Line ending set to in the Serial monitor ?
it works i was setting up the line ending on New line i change it to No line ending .thanks
thank you all guys for your help
