Serial Baudrates with P5
I’m working with Wiring, but it might be P5-Serial related question.
When I set a better baudRate than 19200 in processing (+wiring), it does’nt work (using FTDI - USB). Could it be a problem with how the serial library is done in Processing?
Did you experienced this before with arduino?
Older versions of the serial libraries in Wiring and Arduino had some problems with baud rates above 19200. Are you using the latest version of Wiring (0006)?
If so, you can try reading the serial data with a program like hyperterminal or zterm. This should tell you if the problem is with Wiring or Processing. You’re probably best off asking in the corresponding forum for more help.
