Serial.begin messes up my 74HC595 Shifter
I am doing a school project that involves lots of Outputs. I need to use one 7segment display so i decided to use shift register. Register works fine until the point i type Serial.begin under my setup(){}. The whole 7 segment goes crazy and random lights starts when booting program. Sometimes all segments are on.
As soon as i remove the Serial.begin line everything works. What to do? Shifter uses same serials that i try to use or what what is happening? I am using Arduino Uno. Thank you. My main is like this:
#include "Display.h"
 pinMode(0, OUTPUT); // ClockPin
 pinMode(1, OUTPUT); // LatchPin
 pinMode(2, OUTPUT); // DataPin
 Ykkonen();
And my Display.h follows
#include "Arduino.h"
void Ykkonen()
  int ClockPin = 0;
  int LatchPin = 1;
  int DataPin = 2;
  digitalWrite(LatchPin, LOW);
  shiftOut(DataPin, ClockPin, LSBFIRST, B10001001);
  digitalWrite(LatchPin, HIGH);
int ClockPin = 0; int LatchPin = 1;
These are the Serial lines. Use other pins.
