Serial.begin() prevents a led changing state
Hello guys,I use standart Uno board connected to my computer via usb cable.There is not any other outer supply voltage connected to my circuit.I am running updated Windows 7 operating system and 1.8.13 Arduino IDE.
Any thoughts on it?
  Serial.begin(); --> if i comment it off,Everything seems to work smoothly
  pinMode(0, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(0, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(0 , LOW);    // turn the LED off by making the voltage LOW
Pin's 0+1 are used for hardware serial, you should not use those pins for anything else than serial communication.
Thanks mate.I don't know how i fell into that trap.
Sugarpasa:
General Ackbar probably had the same consideration, IT'S A TRAP!! :stuck_out_tongue:
Serial.begin();
and if you do want to use Serial communication, at what speed ?
