Serial begin
when I use this code on Arduino MEGA the proteus simulation is not running and I receive this error.
when I delete the serial. begin the code is running. is there is any other simulation programs I can use?
"PC=0x00EE. [AVR USART 3] Writing to UDR3 while transmission is not enabled. Data will be ignored. [ARD1]"
#define trigPin 9
#define echoPin 10
long duration;
int distance;
  pinMode(trigPin,OUTPUT);
  pinMode(echoPin,INPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
Serial.print("Distance: ");
Serial.println(distance);
Does a simple "Hello World" print program work ?
What happens if you try a Uno instead of a Mega ?
UKHeliBob:
no, the simulation is refusing any serial line
the Arduino UNO is working perfectly
I think the problem is from the simulator maybe there is some problems in the design
So do you have real hardware or are you forced to use a simulator?
maybe tinkercad?
best regards Stefan
