Dear Sirs,
I wanted to modify a home alarm and use an old Siemens (with his Sync Station which through a serial port communicates with a PC for the normal people) to send SMS.
I found the MaxSerial board perfect for attaching the output to the cable of the Sync Station but I don't know why it doesn't work.
I have uploaded the code and the board works perfectly and in the 'serial monitor' appears the commands that the board sends. The telephone attached to the serial port of a PC works, you send the commands using an hyperterminal and it sends the SMS, so the problem is not the Siemens terminal.
The problem comes when I attach the board to the telephone, I think it comes because the different voltages. To trace the code I have put different blinking of the control led and when the board is attached to the telephone the first blink of a serie has a shorter duration. The MAX232 compatible chip afirms to say it is RS-232 compatible but until now not for me
Can anyone tell me something about this?
Thanks in advance and regards.
