Serial buffering Issue - Arduino Due
Hi guys,
I have been working on arduino for a while now. Currently, i am trying to integrate a wind sensor (LCJ CV7-v) to arduino due. I am using arduino IDE 1.6.5.
Details of wind sensor:
  • flux every 533 milliseconds
  • end of sentence is CR or LF
  • baud rate: 4800
    example output is as follows:
$WIXDR,C,024.0,C,54
$PLCJ,5AFF,63FF,AA,3434,4142
$PLCJE7DB8,73AE,3300,2162,64,
$IIMWV,316.0,R,000.0,N,A
39
Code that i am working on is attached in this post. Also attached is the sensor output that i am getting.
With the output that i get, it seems to me that somehow that bytes are getting dropped as the buffer becomes full.
I have tried to play around with the delay timings and it seems a delay of 533 millis works best.
I am not quite sure what’s going on though.
I referred to http://forum.arduino.cc/index.php?topic=58995.0 thread also, but it dint help my cause.
Please help me in this regard. :confused:
Thanks!
wind_sensor_driver.ino (1.4 KB)
wind_sensor_output.doc (37 KB)
What is your goal?
$WIXDR,C,024.0,C,,*54 => Weather Instrument,CrossTrackError–Dead Reckoning. ( 24.0 deg C)
$IIMWV,316.0,R,000.0,N,A*39 => Integrated Instrumentation,Wind Speed and Angle ( no wind direction 316 deg, R=relative to sensor, N=knots, A=valid data )
$PLCJ,5AFF,63FF,AA,3434,4142 and => Proprietary Code - check manual $PLCJE7DB8,73AE,3300,2162,64,
@knut_ny, Thanks for the reply.
Ultimately i want to extract the wind speed, angle and temp from the packet string in every 15 min interval. But even before that, i am making a check whether or not i am receiving correct data set every time, which unfortunately is not the case because of the bytes getting dropped after some time.
Output comes like this: (as in the attachment in my first post) $ WIXDR,C,024.0,C,,*54 $PLCJ,6AFF,5501,2C,3434,3333 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,271.0,R,000.0,N,A*39 $W IXDR,C,024.0,C,,*54 $PLCJ,6AFE,56FE,2C,3444,3433 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,316.0,R,000.0,N,A*39 $W IXDR,C,024.0,C,,*54 $PLCJ,6AFF,56FE,2C,3444,3433 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,137.0,R,000.0,N,A*38 $WI XDR,C,024.0,C,,*54 $PLCJ,5AFF,6300,AA,3434,4242 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,227.0,R,000.0,N,A*3A $WI XDR,C,024.0,C,,*54 $PLCJ,5AFE,63FF,AA,3334,4142 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,316.0,R,000.0,N,A*39 $WI XDR,C,024.0,C,,*54 $PLCJ,5AFF,63FF,AA,3334,4142 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,137.0,R,000.0,N,A*38 $WIX DR,C,024.0,C,,*54 $PLCJ,5AFF,63FE,AA,3434,4042 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,316.0,R,000.0,N,A*39 $WIX DR,C,024.0,C,,*54 $PLCJ,5A00,63FE,AA,3434,4042 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,316.0,R,000.0,N,A*39 $WIX DR,C,024.0,C,,*54 $PLCJ,5AFF,63FF,AA,3434,4142 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,271.0,R,000.0,N,A*39 $WIX DR,C,024.0,C,,*54 $PLCJ,6AFF,55FE,2C,3434,3333 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,316.0,R,000.0,N,A*39 $WIXD R,C,024.0,C,,*54 $PLCJ,6AFE,55FF,2C,3434,3433 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,271.0,R,000.0,N,A*39 $WIXD R,C,024.0,C,,*54 $PLCJ,6AFF,5500,2C,3434,3333 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,227.0,R,000.0,N,A*3A
Is this something to do with serial buffering? Although, buffer size i came to know is 128 bytes and this packet string is 113 bytes long. So overflow seems unlikely i believe. Please let me know if my understanding is correct. Much appreciated. Thanks!
samarth003: Hi guys,
I have been working on arduino for a while now. Currently, i am trying to integrate a wind sensor (LCJ CV7-v) to arduino due. I am using arduino IDE 1.6.5. Details of wind sensor: - flux every 533 milliseconds - end of sentence is CR or LF - baud rate: 4800 example output is as follows:
$WIXDR,C,024.0,C,,*54 $PLCJ,5AFF,63FF,AA,3434,4142 $PLCJE7DB8,73AE,3300,2162,64, $IIMWV,316.0,R,000.0,N,A*39
Code that i am working on is attached in this post. Also attached is the sensor output that i am getting. With the output that i get, it seems to me that somehow that bytes are getting dropped as the buffer becomes full. I have tried to play around with the delay timings and it seems a delay of 533 millis works best. I am not quite sure what's going on though. I referred to http://forum.arduino.cc/index.php?topic=58995.0 thread also, but it dint help my cause.
Please help me in this regard. :confused: Thanks!
Don't use delay. Just process the serial characters. Here is an example to echo serial from one port to the other in blocks.
echo from Serial2.read to Serial.print by crlf or 114 char block
void setup(){
Serial.begin(57600);
Serial2.begin(4800);
#define MAXBUFFER 128
char buffer[MAXBUFFER];
uint8_t pos=0;
void processSerial(){
char ch = Serial2.read();
if ((ch =='\n')||(ch=='\r')) {
   if(pos>0){ // don't send a blank line for each crlf element
     buffer[pos]= 0; // set end marker.
     Serial.println(buffer);
     pos=0;
else {
  buffer[pos++]=ch;
if(pos>114){ // self imposed max length?
  buffer[pos]=0;
  pos=0;
void loop(){
  if(Serial2.available()) processSerial();
Chuck.
