So I wrote this code here that basically asks you for a character, saves it in a string and then checks that character against all the if statements and activates the appropriate motors when it gets the right if statement (I'm trying to make mechanical braille)
/*Open the Serial Monitor and set the 'baudrate' to 9600
Also, in the Serial Monitor, on the bottom, set it to 'no line ending', not 'newline' or any other setting*/
#include <Servo.h>
Servo servo_8;
Servo servo_9;
Servo servo_10;
Servo servo_11;
Servo servo_12;
Servo servo_13;
String bC; //Braille Character
int angle = 20; //Angle when activated
void clearBraille() { //Sets all pins to 0°
servo_8.write(0);
servo_9.write(0);
servo_10.write(0);
servo_11.write(0);
servo_12.write(0);
servo_13.write(0);
void checkBraille() { //Checks every character and picks correct braille character
if (bC == "A" || bC == "1") {
servo_8.write(angle);
else if (bC == "B" || bC == "2") {
servo_9.write(angle);
else if (bC == "C" || bC == "3") {
servo_11.write(angle);
else if (bC == "D" || bC == "4") {
servo_12.write(angle);
else if (bC == "E" || bC == "5") {
else if (bC == "F" || bC == "6") {
else if (bC == "G" || bC == "7") {
else if (bC == "H" || bC == "8") {
else if (bC == "I" || bC == "9") {
else if (bC == "J" || bC == "0") {
else if (bC == "K") {
servo_10.write(angle);
else if (bC == "L") {
else if (bC == "M") {
else if (bC == "N") {
else if (bC == "O") {
else if (bC == "P") {
else if (bC == "Q") {
else if (bC == "R") {
else if (bC == "S") {
else if (bC == "T") {
else if (bC == "U") {
servo_13.write(angle);
else if (bC == "V") {
else if (bC == "W") {
else if (bC == "X") {
else if (bC == "Y") {
else if (bC == "Z") {
servo_8.attach(8);
servo_9.attach(9);
servo_10.attach(10);
servo_11.attach(11);
servo_12.attach(12);
servo_13.attach(13);
Serial.println("Enter a Character:"); //Asks to type a character
while (Serial.available() == 0) { //Stops anything from happening until a character is typed
bC = Serial.readString(); //Gives string variable 'bC' the inputted value
clearBraille();
checkBraille();
It assigns the inputted character to the String variable but yet it for some reason never finds a match in the if statement function (void checkBraille()). There are no errors either.
