Serial Comm between Arduinos
Hey all,
Im trying to make a laser maze game and want to get 2 Uno's talking to each other through Serial.
I have them wired up accordingly:
Arduino #1 Arduino #2
Tx -----> Rx
Rx -----> Tx
Gnd -----> Gnd
I've gotten a message successfully sent & received from #1--->#2, but fail a get a message through from #2--->#1
Here's my code:
Arduino #1:
unsigned long tempus;
long score;
int laserBreakOn = 300;
int trigger = 1;
  for (int pin = 9; pin <= 13; pin++){                            //initialize laser pins
    pinMode(pin, OUTPUT);
    digitalWrite(pin, HIGH);
tempus = millis();
score = 40000 - (tempus/5);
Serial.println(score);
if (analogRead(A0) < laserBreakOn){digitalWrite(9, LOW);}
if (analogRead(A1) < laserBreakOn){digitalWrite(10, LOW);}
if (analogRead(A2) < laserBreakOn){digitalWrite(11, LOW);}
if (analogRead(A3) < laserBreakOn){digitalWrite(12, LOW);}
if (analogRead(A4) < laserBreakOn){digitalWrite(13, LOW);}
  if (digitalRead(7) == 1){                                       //end sequence
    int laserBreakCount = 0;
     if (digitalRead(pin) == 0){
       laserBreakCount++;
    Serial.write(trigger);
    delay(5);
    int incoming = Serial.read();
    laserBreakCount = laserBreakCount + incoming;
    score = score - (1000*laserBreakCount);
    Serial.print("Final Score:");
    Serial.end();
Arduino #2:
  for (int pin = 8; pin <= 9; pin++){                            //initialize laser pins
  if (analogRead(A0) < laserBreakOn){digitalWrite(8, LOW);}
  if (analogRead(A1) < laserBreakOn){digitalWrite(9, LOW);}
    if (incoming == 1){                                           //end sequence
      Serial.println("I READ ONE");
      int breakCount = 0;
         breakCount++;
     Serial.write(breakCount);
     Serial.end();
When #1 goes through its end sequence, it successfully sends trigger to #2 and #2 begins its own end sequence, and i know breakCount successfully iterates to the number of broken lasers.
What i was then hoping that would happen after was that #2 writes breakCount to #1 and then #1 would add that to it's laserBreakCount.
BUT I can only get #1 to receive (or at least interpret what it's received) as a -1.
This is my first project involving Serial Comm between arduinos. I've looked at Robin2's great tutorial and numerous other places, but I just cant get these two talking for the life of me. The world of Serial just doesnt make sense to me yet.
Thanks ahead of time for all the help!
If there's any extra info you might need to know I'll do my best to provide.
If the serial is the problem, why don't you write a simple sketch to test that instead of big sketches which should use it?
http://robotic-controls.com/learn/arduino/arduino-arduino-serial-communication
Ray
Use the 3rd example in Serial Input Basics - simple and reliable. Use it on both Arduinos if necessary.
It would make debugging easier if you use SoftwareSerial on the two Unos for create an extra serial port for the communication between them. Then you can print debug messages on HrdwareSerial and view them on the Serial Monitor.
As @septillion has said, get the comms working with a simple program first.
...R
