Serial comm question
Hi
I am working on a project and in troubleshooting it I think I found the issue but I don’t know what is causing it. I am using an arduino mega for this project.My code is shown below
int val;
if (Serial.available() > 0) // wait for data
char val = Serial.read(); // reads the value of serial input
if ( 0 <= val < ‘10’) // bottom of speedometer
Serial.print(0);
else if (val >= ‘10’); // bottom of speedometer to servo endpoint
Serial.print(val);
/else if (val < ‘94’); // servo endpoint
Serial.println(180);
The problem I am having is that when I put a number into the serial monitor, 35 for instance, it prints the number 03050 instead of 35. What could cause this?
Thanks
Tanner
This reads one character at a time
This is trying to compare against 2 characters, it’s true every time
      if ( 0 <= val < '10') // bottom of speedometer
        Serial.print(0);
To reiterate that, you can't get "10" in one read. That's two separate characters, a '1' and a '0'.
Also note that single quotes are for single characters only. You can't put anything in single quotes that you can't type with one single stroke on your keyboard.
Have a look at the examples in Serial Input Basics. They are simple and reliable.
...R
