Hey all, any help with this is much appreciated. Here’s my setup: I’m using the Arduino to communicate with a temperature monitor (which receives a reading from a PRTD)via serial port. The monitor needs a query of the form “KRDG? [term]” to respond with a kelvin temperature reading, where [term] are terminating characters (line feed and carriage return). The returned value according to the manual will be of the form “+nnnnnn” where n is an integer OR a decimal (temp monitor has 5 digit precision, so it will shift one place when going from <100 to >100). Seems like it ought to be fairly straight forward, but when I run my code (below), I get an output of zeroes. If I make the temp[11] array of the char type, I get unprintable characters. I use 11 elements because the temp monitor transmits one start bit, 7 bits for data in ASCII characters, one parity bit (odd), and one stop bit, plus the null character from the Arduino.
Could the zeroes/unprintable chars be a result of reading form the serial buffer incorrectly? Any advice is much appreciated. If I’ve left something out or need clarification, I’ll tell all I can.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3); //(RX,TX)
int temp[11]; //char array to be temp acquired
int n; //counting number
mySerial.begin(9600);
mySerial.write("KRDG? \r\n"); //Send query to temp monitor
while(mySerial.available()>0)
for(n=0; n<11; ++n)
temp[n] = mySerial.read();
for(n=0; n<11; ++n)
Serial.print(temp[n]);
All that stuff about bits is telling you the protocol that is used to put a single byte on the wire - it says nothing about how many bytes you'll get. The number of bytes received will determine the size of the buffer required (plus one for the null as you observe). +nnnnnn suggests you'll need eight, although I'd add a few extra until you've sorted out what you actually get.
Note also, that you will need to mask out the parity bit - the arduino is not expecting it, so ~half your characters will display as garbage until you do.
Sorry about that confusion. I was looking at one thing and typing another. I understand that Serial.read() gathers one BYTE at a time, rather than individual bits; thus 8 elements per array will suffice.
Forgive me for not knowing, but I've looked around with no luck on how to mask out a single bit. I've read concept material and I think I grasp it, but I'm at a loss when coding. Any useful links? I've found the following thread in my search; maybe someone could point out which parts are necessary to the masking?
Many thanks for the replies thus far. I’ve placed a Serial-TTL converter between the temp monitor and Arduino, so I’m closer to my goal, but I’m still getting garbage output. When I run the code shown here, I get a different number of received bytes every time.
int temp[10]; //int array to be temp acquired
mySerial.write("\xCB\x52\xC4\xC7\xBF\x20\x0D\x8A"); //Send query to temp monitor
n=0;
temp[n] = mySerial.read(); & 0x7F;
++n;
Serial.println(n);
for(n=0; n<8; ++n)
I’ve checked the output of the Arduino on an oscilloscope only and I can see a digital signal being sent, but when I connect it to the temp monitor via the converter I get a very small signal (~300mV). Can anyone see something I’ve missed regarding the Arduino code, or perhaps an electrical limitation with it?
I am currently trying to verify everything with the temp monitor is working properly (the digital readout is working), but I cannot seem to get Hyper Terminal to send the correct query. If anyone knows why it wouldn’t be sending after I check “echo typed characters locally”, I’d love some advice.
