Serial Comm with pyscript
if results.multi_hand_landmarks: # if this statement is true, enter the for loop
ic = '1'
command = ic
serialInst.write(command.encode('utf-8'))
The pyscript is a mediapipe code. the serial prints fine
on my C side i have this in my loop
if (Serial.available() > 0) {
String(msg) = Serial.readString();
Serial.println("Message:");
Serial.println(msg);
i noticed the serial monitor only prints like this Message:"0000000000000011111111111111111"
while i was expecting it to print like
Message:0
Message:1
Message:0
which is like the big issue because i need the message to be split so the controls .
int ledpin = 2;
int buzzer = 3;
int n = 1;
  pinMode(ledpin, OUTPUT);
  pinMode(buzzer, OUTPUT);
    digitalWrite(ledpin, HIGH);
    if (msg == "1") {
      digitalWrite(buzzer, HIGH);
    else if (msg == "0") {
      delay(200);
      digitalWrite(buzzer, LOW);
  else {
    digitalWrite(ledpin, LOW);
C Code
import cv2
import mediapipe as mp
import time
import serial.tools.list_ports
webcam = cv2.VideoCapture(0)
mpHands = mp.solutions.hands  #Default set code for hand tracking. Ritual Required
hands = mpHands.Hands()
mpDraw = mp.solutions.drawing_utils
ports = serial.tools.list_ports.comports()   #Listing available ports
serialInst = serial.Serial() #created instance
portsList = [] # variable to hold port list
for onePort in ports:
    portsList.append(str(onePort))
    print(str(onePort))
val = input("Select Port: COM")
for x in range(0,len(portsList)):
    if portsList[x].startswith("/dev/ttyACM" + str(val)): #on windows the port starts with the 'com' sequence // ports on linux follow the format '/dev/ttyACM'
        portVar = "/dev/ttyACM" + str(val)
        print(portVar)
serialInst.baudrate = 9600
serialInst.port = portVar
serialInst.open()
while True:
    ret, frame = webcam.read()
    imguse =  cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)  # Images used by mediapipe are in RGB color spaces
    results = hands.process(imguse)
    print (results.multi_hand_landmarks)  # getting the exact hand landmark location
        ic = '1'
        command = ic
        for handLms in results.multi_hand_landmarks:
            for id, lm in enumerate(handLms.landmark): # without handLms we can directly enumerate results.multi_hand_landmarks
                h,w,c = frame.shape
                cx, cy = int (lm.x * w), int (lm.y * h)
                print  (id, cx, cy)
            mpDraw.draw_landmarks (frame, handLms, mpHands.HAND_CONNECTIONS)
      #set mpDraw outside the loop as usual. The parameters are (what display image, how many hands Hand LMS means single hand, connection line between dots )
    else :
        ic = '0'
        command = ic
                h,w,c = frame.shape
                print  (id, cx, cy)
    cv2.imshow('frame', frame)
    if cv2.waitKey(25) & 0xFF == ord('x'):
        cv2.destroyAllWindows()
        break
webcam.release()
Py COde
If you want one character, why not use Serial.read()?
