Serial Command to Arduino activating Ping Sensors
Hello All, Good Day! :)
I am a bit new to Arduino.
What I want to do is activate a loop within the arduino code when a Serial command is activated. I want to control a DC motor with my PC keyboard, and I also want the motors to be controlled with Ping Sensors, but the ping sensor part would only be activated when a particular button lets say 'z' is pressed on my laptop keyboard.
Attached is the code I have so far. Note: I haven't added anything concerning the sensors as yet.
const int motor =8;
const int motor2 =9;
const int motor3 =10;
  pinMode(motor, OUTPUT);
  pinMode(motor2, OUTPUT);
  pinMode(motor3, OUTPUT);
  Serial.println("Motor Control");
  if (Serial.available() > 0) {
    int data = Serial.read();
    switch(data)
        case 'a' :  digitalWrite(motor, HIGH); Serial.print("Vertical Push Down - ON");break ;
    case 'b' :  digitalWrite(motor, LOW); Serial.print("Vertical Push Down - OFF"); break ;
        case 'c' :  digitalWrite(motor2, HIGH); Serial.print("Motor One - Activated"); break;
        case 'd' :  digitalWrite(motor2, LOW); Serial.print("Motor One - OFF"); break;
        case 'e' :  digitalWrite(motor3, HIGH); Serial.print("Motor Two - Activated"); break;
        case 'f' :  digitalWrite(motor3, LOW); Serial.print("Motor Two - OFF"); break;
You need a state vaiable than can remember what state you are in currently based on events in the past.
#define SENSOROFF 0
#define SENSORON 1
int sensorState = SENSOROFF;
 ...  // keep as is
    switch(data)
        case 's' : sensorState = SENSORON;   break;
        case 'z' : sensorState = SENSOROFF;   break;
    if (senssorState == SENSORON)
        /Do something with your sensor here. when you send an 's' via serial, this part will continusly execute every time in the loop until you send a 'z'.
