Serial commands to Arduino 328
Hello there,
This is my first post here so here it goes! :slight_smile: I am trying to make an Arduino to start a motor when it receives 1 clockwise,2 counterclockwise and 0 to stop. The speed is increasing in time but this is not the problem. Well i have created a sketch which receives data at 9600 from the serial interface. I have also created a program in VB 2008 where i sent 1,2 and 0 through the serial port (FTDI) and it works. The problem arises when i try to write a program in C in Linux (LXDE over Ubuntu). The rx led on the Arduino board blink when the message is sent but the motor is not starting whatever i do. I even tried to change the receive buffer to be above or equal 0 but still nothing. :frowning: This is very confusing since i have configured my program to sent CS8( 8 bits per byte), B9600 (9600), No parity bit and one stop bit (same as the VB program). I use /dev/ttyUSB0 as the serial port file in C program. Does any one have a clue what is going on? I am really desperate since this is part of a University Project in robotics. Thanks a lot! (forgive my English if they are not OK i am a foreign)
Please post your C code. It is probably some simple like writing numbers to the serial port, instead of characters. Without the code, though, we can't tell.
By the way, you were doing great until that last sentence where you said that English is not your native language.
Post the Arduino code, too.
Thanks for the reply!
The arduino code is:
// motor A
int dir1PinA = 13;
int dir2PinA = 12;
int speedPinA = 10;
unsigned long time;
int speed; //This is the speed variable for the motors
int inbyte=-1; //This is the received command
Serial.begin(9600); //setup the serial port to 9600bps
//seting the pins options
pinMode(dir1PinA, OUTPUT);
pinMode(dir2PinA, OUTPUT);
pinMode(speedPinA, OUTPUT);
//initializing the time and the speed
time = millis();
speed = 0;
if (Serial.available()>0){ //check if something was received
inbyte==Serial.read(); //store it to inbyte
if (inbyte>-1){ //this is acknowledgment
Serial.print(“Received1”);
Serial.print( inbyte);}}
else{ //if the serial is not available
delay(10); //wait for 10ms and try again
inbyte=Serial.read();
if (inbyte>-1){ //acknowledgment
Serial.print(“Received2”);
analogWrite(speedPinA, speed);
// set direction
if (inbyte==49) { //if the received command is 1 in ASCII code start spinning
Serial.print(“Starting…”);
digitalWrite(dir1PinA, LOW);
digitalWrite(dir2PinA, HIGH);
} else{
if(inbyte==50) {//if the received command is 2 in ASCII code start spinning
digitalWrite(dir1PinA, HIGH);
digitalWrite(dir2PinA, LOW);
else {
if (inbyte==48){ //if the received command is 0 in ASCII code stop
digitalWrite(dir1PinA,LOW);
if (millis() - time > 5000) { //increment speed until it reaches 255 (this will be changed in the future)
time = millis();
speed += 20;
if (speed > 255) {
speed = 0;
The C code is:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <termios.h>
//PROTOTYPE DECLARATION POINT
char menu();
int open_port();
// MAIN FUNCTION
int main(){
char msg; //the message
int fd; //file descriptor
int n;
fd=open_port(); //this will get the file descriptor
msg=menu(); //this will get the command from the user
struct termios options; //setting the options termios
tcgetattr(fd,&options); //getting the current attributes of the fd
cfsetispeed(&options,B9600); //setting the speed to 9600
cfsetospeed(&options,B9600);
options.c_cflag &=~CSIZE; //setting the size of bits per byte
options.c_cflag |=CS8; //setting 8bits per byte
options.c_cflag &=~PARENB; //dissabling parity bit
options.c_cflag &=~CSTOPB; //one stop bit
n=write(fd,&msg,1); // sent the command
close(fd); //close port
return 0;
//FUNCTION DECLARATION POINT
char menu(){ //this is a menu for the user to enter a value
char val;
printf(“Please enter a value:\n”);
printf(“0:Stop\n”);
printf(“1:Counterclockwise\n”);
printf(“2:Clockwise\n”);
val=getchar();
return val;
int open_port(){ //this will open the port
int fd;
fd=open("/dev/ttyUSB0",O_RDWR | O_NOCTTY | O_NDELAY);
if (fd==-1)
{printf(“error on opening”);
return fd;}
else{
fcntl(fd, F_SETFL,0);
printf("%d",fd);
return fd;
return fd;
In the sketch, you have this:
This will compare the value returned by the Serial.read function to the value currently in inbyte. No action is taken if the values are equal, or not. inbyte is NOT modified.
If Serial.available said there was no data available, waiting 10 milliseconds will not make some appear.
A month from now when you look at this, you’ll be scratching your head, wondering what that was all about. It’s better to do this:
if(inbyte == '1') {
You could change the characters from 1, 2, and 0 sometime, to F, B, and S (for foreward, backward, and stop). It would be easy to change ‘1’, ‘2’, and ‘0’ to ‘F’, ‘B’, and ‘S’. It’s more difficult to change 49, 50, and 48. You’d have to go look up what the ASCII equivalents are. Why not just let the compiler to that for you?
I don’t see anything obviously wrong with the C code. I wonder if /dev/ttyUSB0 is the correct port to be using. Is ttyUSB0 the port that the Arduino is on? Do you have permission to write to that device?
Maybe one of the linux users could help you determine if ttyUSB0 is correct and whether you are (or can) use it (right).
Thanks for the recommendations! :) I have changed the code as recommended. For the C program i have searched a lot to finally discover that ttyUSB0 is the file that i am needing. I also made some tests myself by unplugging arduino and replugging it. The file disappeared and reappeared at each time. The thing with this program is that RX led on the arduino board is blinking each time it receives from the program but the motor is not spinning. I believe there is something to do with the file not setting right or at all. I even tried from the root terminal executing the program and even changing the file permissions by chmod -a+rw command. Its still very puzzling what is going on.... :-/ Any ideas?
If the RX light flashes when the program is trying to send data to the Arduino, and only then, then, clearly, the Arduino IS receiving the data.
It would suggest that it is the Arduino that is not interpreting the data correctly. I would add some statements to echo the input. The C program would then need to be modified to read what was written back, and display it.
I’d also add some printf statements in the C program to verify that a valid character was received in menu (by the getchar function).
Thanks a lot for the help! I have finally made it! The motor started spinning as requested! There are some changes in the C code but i believe that the actual thing that made this work is the chmod 0666 /dev/ttyUSB0
This is the C code with some minor changes:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <termio.h>
char menu();
int open_port();
// MAIN FUNCTION
int main(){
      int n;
      char buffer[12];
      options.c_iflag=IGNPAR;
      options.c_oflag=0;
      options.c_cflag= CS8 | CREAD | CLOCAL;
      options.c_lflag=0;
      tcsetattr(fd,TCSANOW,&options);
      int i;
      for ( i=0; i<11; i++){
            read(fd,&buffer[i],1);
      printf("%s",buffer);
return 0;
      char val;
            printf("Please enter a value:\n");
            printf("0:Stop\n");
            printf("1:Counterclockwise\n");
            printf("2:Clockwise\n");
            val=getchar();
            //printf("%s",val);
      return val;
      int fd;
      fd=open("/dev/ttyUSB0",O_RDWR);
      if (fd==-1)
      {printf("error on opening");
      return fd;}
      else{
      printf("%d",fd);
      return fd;
return fd;
Thanks a lot for the help! :smiley:
PS: I found how to correctly add the code in the forum
