Serial commands to Arduino mega 2560
Hey all,
I have read a lot of post about serial communication but its still not working here. On my arduino mega i have the following running:
int ledPin = 13;
int state=0;
    pinMode(ledPin, OUTPUT); // pin will be used to for output
    Serial.begin(9600); // same as in your c++ script
  if (Serial.available() > 0)
    state = Serial.read(); // used to read incoming data
    switch(state)// see what was sent to the board
      case '1': // if the the one was sent
        digitalWrite(ledPin,HIGH);
      case '0': // if 0 was sent
        digitalWrite(ledPin,LOW);
      default:
On my pc I have the Serial Class like its found here: see reply below
Then I wrote the next simple code:
#include "SerialClass.h"
#include < iostream >
int main( int argc, char **argv )
      Serial mySerial("COM4");
    std::cout << mySerial.IsConnected() << std::endl;
      system("PAUSE");
    return 0;
it compiles fine but when i run it it tells me it cant connect to COM4, while the ArduinoIDE can upload the code trough COM4.
Anybody know why its not working?
Cheers,
Xander
I was not allowed to post the link in the first post: http://www.arduino.cc/playground/Interfacing/CPPWindows
Do you have the arduino serial port "on" when you try the code? Try running the code without the Arduino IDE running.
Yes, but I have already tried it when its not running. I know the its not going to work with the serial monitor on but I don't have that on either.
I believe there are problems with that serial wrapper. Folks have reported success with this one... http://www.codeproject.com/KB/system/serial.aspx
