I am trying to write an application for the arduino that will communicate with my PC via USB. This works fine while using the "Serial Monitor" within Arduino. But when I try and use some seperate software, the arduino seems not to respond, and even the LED on pin 13 illumiates slightly (i assume to let me know that there is an error) does anyone have and ideas what this means or what the error is?
No pin 13 has no such function, it could be you still have the arduino's serial monitor connected or there is some other hardware fault but pin 13 should not change unless you write code to change it.
Are you all sure. I have noticed when I open the arduino serial monitor it always opens a comms session on the same port. When as the dll I am using seems to just pick any port. Are you sure that it is not the operating system that runs in the arduino not letting me?
For example, what happens if I just happend to send the right sequence of characters down the serial port that would place the Arduino into "Program" mode. Is this not catered for by the operating ssytem/enviroment?
You are quite welcome to look at my code…
It received a message, validates it’s checksum, and once it has a valid message, it sends a valid message back.
Also, There is nothing wrong with the LabVIEW code I am using, as I was the one who wrote it and have been using it sucsesfully for over a year.
int inByte = 0; // incoming serial byte
int x = 0;
int potentialCheck = 0;
int actualCheck = 0;
int DCPstart, DCPflag0, DCPflag1, DCPkey, DCPseq, DCPid, DCPlen, DCPdst, DCPsrc;
int DCPhdrChk1, DCPhdrChk2;
int DCPIncomingMessage[23];
int newCheckSum;
boolean DCPreading, stopReadingDCP, messageAwaitingProcessing;
int DCPbyteReadCount = 0;
// start serial port at 9600 bps:
establishContact(); // send a byte to establish contact until receiver responds
DCPreading = false;
// if we get a valid byte, read analog ins:
if (Serial.available() > 0) {
// get incoming byte:
inByte = Serial.read();
if (DCPreading == true) // Are we still reading the message?
DCPIncomingMessage[DCPbyteReadCount] = inByte; // Add next byte to array
DCPbyteReadCount = DCPbyteReadCount + 1; // Keeps check of how many bytes we have read
if (DCPbyteReadCount >= 12)
validateChecksum(); // is it a complete message?
if (stopReadingDCP == true) // have we reached the end of the message?
DCPreading = false; // stop next time around
messageAwaitingProcessing = true;
if (inByte == 83) // Is this the start of a DCP message
DCPIncomingMessage[0] = inByte; // place the first byte into the beginning of the array
DCPreading = true; // let us know that we are part way through reading a message
DCPbyteReadCount = 1; // reset the byte count
if (messageAwaitingProcessing == true)
DCPstart = DCPIncomingMessage[0];
DCPflag0 = DCPIncomingMessage[1];
DCPflag1 = DCPIncomingMessage[2];
DCPseq = DCPIncomingMessage[3];
DCPid = DCPIncomingMessage[4]*100+DCPIncomingMessage[5];
DCPdst = (DCPIncomingMessage[6]*1000000)+(DCPIncomingMessage[7]*10000)+(DCPIncomingMessage[8]*100)+(DCPIncomingMessage[9]);
newCheckSum = DCPstart ^ DCPflag0 ^ DCPflag1 ^ DCPseq ^ DCPid ^ DCPdst;
Serial.print(DCPstart,BYTE);
Serial.print(DCPflag0,BYTE);
Serial.print(DCPflag1,BYTE);
Serial.print(DCPseq,BYTE);
Serial.print(DCPid,BYTE);
Serial.print(DCPdst,BYTE);
Serial.print(newCheckSum,BYTE);
// PAYLOAD SHOULD BE DELIVERED HERE
//Serial.print("I'M SOMTHING NEW!",BYTE);
messageAwaitingProcessing = false;
void establishContact() {
while (Serial.available() <= 0) {
delay(300); // Wait until device is communicated with
void validateChecksum() {
// if the checksum is valid
x = 0;
potentialCheck = DCPIncomingMessage[0]; // Add first Value into check
do
x = x + 1; // Ensure the first value is XORed by the second
potentialCheck = potentialCheck ^ DCPIncomingMessage[DCPbyteReadCount]; // XOR each value
while (x < DCPbyteReadCount - 2);
actualCheck = DCPIncomingMessage[DCPbyteReadCount - 1]; // Add First Value
actualCheck = actualCheck *100; // Shift up 2
actualCheck = actualCheck + DCPIncomingMessage[DCPbyteReadCount]; // Add Second Value
if (actualCheck == potentialCheck)
stopReadingDCP = true; // This flag is only set if a valid checksum is identified
