Serial Communication and Blocking vs NonBlocking Functions
So, I've tested everything out (now with my application sending the data to the Arduino instead of just entering in a string in the serial monitor)... and it seems to be working well. There's still an issue with it sending an extra 'next' statement every time it receives a message. I could keep a counter and only send when the counter mod 2 returns zero... but this seems like it's putting a bandaid on the initial problem. I can't seem to figure out why it's sending the extra 'next' statement. The code I'm using is:
if (motorRun == 1) {
while(1)
moving_1 = stepper1.run(); //tell the motors to move to their positions
moving_2 = stepper2.run();
moving_3 = stepper3.run();
moving_4 = stepper4.run();
if(!moving_1 && !moving_2 && !moving_3 && !moving_4){
motorRun = -1; //reset the MotorRun variable
Serial.println("n"); //send character for the next line from Firefly
moving_1 = true; //reset the moving flags
moving_2 = true;
moving_3 = true;
moving_4 = true;
The moving variables are all initialized as true and they're all reset after the if statement... so it should never jump out of the while loop unless all motors are at their final position. Since it's sending two 'next' statements, I think I'm actually asking for the next string of data from my application immediately... so I don't think I'm actually losing data, it's just making the movement jerky. Do you have any thoughts?
Thanks,
Andy
Some of the code...
It is not necessary to set moving_n flags to true, They are not checked before being set, so it doesn't matter if they get set somewhere else to Tuesday.
So, we need to look at the rest of the code. One possibility that might be causing issues would be sending the string followed by \n\r or two \n's.
Fair enough. Here's the whole code.
#include <AccelStepper.h>
#define BAUDRATE 115200 //Set the Baud Rate to an appropriate speed
#define BUFFSIZE 256 // buffer one command at a time, 12 bytes is longer than the max length
#define DIR_PIN_A 2 //Set Direction Pin for Stepper A to Digital Pin 2
#define STEP_PIN_A 3 //Set Step Pin for Stepper A to Digital Pin 3
#define DIR_PIN_B 4 //Set Direction Pin for Stepper B to Digital Pin 4
#define STEP_PIN_B 5 //Set Step Pin for Stepper B to Digital Pin 5
#define DIR_PIN_C 6 //Set Direction Pin for Stepper C to Digital Pin 6
#define STEP_PIN_C 7 //Set Step Pin for Stepper C to Digital Pin 7
#define DIR_PIN_D 8 //Set Direction Pin for Stepper D to Digital Pin 8
#define STEP_PIN_D 9 //Set Step Pin for Stepper D to Digital Pin 9
long motorPos[4] = {0,0,0,0};
int motorSpeed = 2000; //Set default speed value
int motorAcc = 1000; //Set default acceleration value
int motorRun = 1; //Set default run value
int motorReset = 0; //Set default reset value
boolean moving_1 = true;
boolean moving_2 = true;
boolean moving_3 = true;
boolean moving_4 = true;
//unsigned long timer = 0;
String msg_char = "";
char *parseptr;
char buffidx;
char buffer[BUFFSIZE]; // this is the double buffer
uint16_t bufferidx = 0; // a type of unsigned integer of length 16 bits
uint16_t p1, s1;
// Define some steppers and the pins they will use: Ex: Accelstepper stepper1(1, 3, 4) <- STEP PIN 3, DIR PIN 4.
AccelStepper stepper1(1, STEP_PIN_A, DIR_PIN_A);
AccelStepper stepper2(1, STEP_PIN_B, DIR_PIN_B);
AccelStepper stepper3(1, STEP_PIN_C, DIR_PIN_C);
AccelStepper stepper4(1, STEP_PIN_D, DIR_PIN_D);
  • SETUP() This code runs once
stepper1.setCurrentPosition(0); //Move steppers to default position
stepper2.setCurrentPosition(0);
stepper3.setCurrentPosition(0);
stepper4.setCurrentPosition(0);
setStepperSpeeds();
Serial.begin(BAUDRATE); // Start serial communication
establishContact(); // send a byte to establish contact until receiver responds
  • LOOP() This code loops continuously
UpdateStepperValues(); //Get all the incoming values from Firefly
if (motorReset == 1) {
stepper1.setCurrentPosition(motorPos[0]);
stepper2.setCurrentPosition(motorPos[1]);
stepper3.setCurrentPosition(motorPos[2]);
stepper4.setCurrentPosition(motorPos[3]);
while(1)
  • UPDATE STEPPER VALUES FUNCTION()
void UpdateStepperValues(){
char c; // holds one character from the serial port
if (Serial.available() > 0) {
c = Serial.read(); // read one character
buffer[bufferidx] = c; // add to buffer
if (c == '\n') {
buffer[bufferidx+1] = 0; // terminate it
parseptr = buffer; // offload the buffer into temp variable
motorPos[0] = parsedecimal(parseptr); // parse the first number
parseptr = strchr(parseptr, ',')+1; // move past the ","
motorPos[1] = parsedecimal(parseptr); // parse the next number
motorPos[2] = parsedecimal(parseptr); // parse the next number
motorPos[3] = parsedecimal(parseptr); // parse the next number
motorSpeed = parsedecimal(parseptr); // parse the next number
motorAcc = parsedecimal(parseptr); // parse the next number
motorRun = parsedecimal(parseptr); // parse the next number
motorReset = parsedecimal(parseptr); // parse the next number
setStepperSpeeds();
stepper1.moveTo(motorPos[0]); //set new absolute target position
stepper2.moveTo(motorPos[1]); //set new absolute target position
stepper3.moveTo(motorPos[2]); //set new absolute target position
stepper4.moveTo(motorPos[3]); //set new absolute target position
bufferidx = 0; // reset the buffer for the next read
return; //return so that we don't trigger the index increment below
// didn't get newline, need to read more from the buffer
bufferidx++; // increment the index for the next character
if (bufferidx == BUFFSIZE-1) { //if we get to the end of the buffer reset for safety
bufferidx = 0;
double parsedecimal(char *str)
return atof(str);
void establishContact() {
while (Serial.available() <= 0) {
Serial.println("waiting..."); // send an initial string
delay(200);
void setStepperSpeeds() {
stepper1.setMaxSpeed(motorSpeed);
stepper1.setAcceleration(motorAcc);
stepper2.setMaxSpeed(motorSpeed);
stepper2.setAcceleration(motorAcc);
stepper3.setMaxSpeed(motorSpeed);
stepper3.setAcceleration(motorAcc);
stepper4.setMaxSpeed(motorSpeed);
stepper4.setAcceleration(motorAcc);
My application (written in C#) does indeed call the Console.WriteLine method... which by default adds a "\r\n" characater at the end of the line (Console.WriteLine Method (System) | Microsoft Learn). I think the Serial Monitor send function also adds these characters. My code does look for the '\n' character as the terminator and then flushes the buffer... But, I don't think this would cause it to update all the values twice would it?
Serial.available() can never return a value less than 0. There is data, or there isn't. There can not be a negative amount.
What does the code on the sending end expect before it sends new data? A specific character, or any character? Is the Serial.println("n") causing it to send just one batch of data or three?
Is it sending data followed by one carriage return, or is it sending data followed by carriage return and line feed? Or something else?
Thanks for the clarification about Serial.available(). The code on the sending end is looking for the 'n' character coming over the serial port. When it receives this character it sets a flag to issue another position command and then resets the incoming buffer to null (or empty). Once the flag has been set, it basically removes the first item from the list (as that was the one that was sent last) and then formats another string getting the next position values for each of the four motors (as well as the current state of the run, speed, acceleration, and reset values). Then, assuming the port is open, it then sends the formatted string back over to the Arduino using the WriteLine(message) command. Looking at this command on the msdn website, it looks like the default behavior of this function automatically adds a '\r\n' character to the end of the line. I'm not adding it on myself... but the command automatically does it. So, then once that command is issued, the Arduino reads in the string and goes through the while loop again. It shouldn't be sending three batches of data ever... Hopefully this helps clarify it a bit.
Does your sender show you all the serial data it gets? Can you send debug information to it?
If so, it would be interesting to know when a complete record is received, relative to when the n's are sent.
