Hello,
I'm using max30100 pule oximeter sensor with temperature sensor ds18b20 with arduino nano. I want it to send these data (heartrate, spO2 , and temperature ) to nodemcu. Then I want to publish these data on thingspeak. How can I read these separately and store in variables in order to publish on cloud?
Note : I'm using arduino nano because I tried the same code on nodemcu it did not work properly.
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SoftwareSerial.h>
#define REPORTING_PERIOD_MS 3000
#define ONE_WIRE_BUS 2
String str;
String str1;
String str2;
void(* resetFunc) (void) = 0;
int t=0;
float h,s,t1;
PulseOximeter pox;
uint32_t tsLastReport = 0;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
SoftwareSerial espSerial(5, 6);//rx,tx
void onBeatDetected()
Serial.println("Beat!");
espSerial.begin(115200);
Serial.print("Initializing pulse oximeter..");
sensors.begin();
// Initialize the PulseOximeter instance
// Failures are generally due to an improper I2C wiring, missing power supply
// or wrong target chip
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
pox.setOnBeatDetectedCallback(onBeatDetected);
// Make sure to call update as fast as possible
pox.update();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
h=pox.getHeartRate();
s=pox.getSpO2();
Serial.print("Heart rate:");
Serial.print(h);
Serial.print("bpm / SpO2:");
Serial.print(s);
Serial.println("%");
sensors.requestTemperatures();
// Fetch the temperature in degrees Celsius for device index:
float tempC = sensors.getTempCByIndex(0); // the index 0 refers to the first device
Serial.print("Temperature: ");
Serial.println(tempC);
Serial.print(" C");
str =String("coming from arduino: ")+String("Heartrate")+String(h);
espSerial.println(str);
str1 = String("SpO2= ")+String(s);
espSerial.println(str1);
str2 = String("temp=")+String(tempC);
espSerial.println(str2);
tsLastReport = millis();
t++;
if(t>8){
resetFunc();
Hello, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation of your ask).
Software serial will not work at 115200 baud (no matter what the reference says). 38400 is the fastest that I have been able to get SoftwareSerial to work reliably.
This the code for nodemcu, Output always shows zero for both parameters (heartrate and spO2), when connected to wifi and thingspeak. Wiring is simple SDA of max30100 to sda of nodemcu, same for scl, Vin of sensor to 3.3 v, ground to ground. Even though I excluded the temperature sensor , output is always zero.
If I don't connect it to the wifi/thingspeak it works.
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <ThingSpeak.h>
#define REPORTING_PERIOD_MS 1000
float h,s;
PulseOximeter pox;
WiFiClient client;
long myChannelNumber = xxxxxxx;
const char myWriteAPIKey[] = "xxxxxxxxxxxx";
WiFi.begin("ssid", "xxxxxxxxx");
while(WiFi.status() != WL_CONNECTED)
Serial.print("..");
Serial.println("NodeMCU is connected!");
ThingSpeak.begin(client);
if (!pox.begin()) {
for(;;);
// Register a callback for the beat detection
void loop(
pox.update();
s=pox.getSpO2();
Serial.print(h);
Serial.print(s);
ThingSpeak.writeField(myChannelNumber, 1, h, myWriteAPIKey);
ThingSpeak.writeField(myChannelNumber, 2, s, myWriteAPIKey);
