I'm not a pro programmer just hobbyist from time to time.
Project includes: 3 x Arduino Uno
They are called:
DaisyChain Master (Lets Call it DC Master)
DaisyChain Middle (DC Middle)
DaisyChain End (DC End)
So the idea is that on all arduinos im using the TX and RX built in and I am also using software serial
step 1 - Idea is that DC Master sends a start data like a 0 using software serial tx and that is received by DC Middle on the Default RX
step 2 - Once DC Middle receives this start data it then sends back some data (default TX) which is fixed for now, currently sending a number 9
step 3 - DC Middle then sends DC End the same start data like a 0 using software serial tx and that is received by DC End on the Default RX
step 4 - DC End now receives this start data it then sends back some data (default TX) which is fixed for now, currently sending a number 62
step5 - Dc Middle receives this data and relays it back to DC Master
step6 - DC Master displays on LCD or Serial monitor screen
Hope this makes sense.
I have a few questions...
1, Am i using the correct monitoring of of serial by using serial.avaible() because i also need to do other things later and cant be stuck waiting for communication to come in.
2, Why does my code send back 9,62,62 its sending back the 62 two times??? why???
EXTRA NOTES:
These Arduino's will be about 100m apart on a farm fence. And there could be up too 10 of them each 100m apart totaling of 1km distance all in all.
CODE: DaisyChain Master
//----------------------------------------------x-------------------------------------
#include <Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int ledPin = 13; // 13 for standard arduino
int start, incoming, counter = 0;
int statusStore[100] ;
// initialize the LCD
lcd.begin();
// Turn on the blacklight and print a message.
lcd.backlight();
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Coms 1 - Ready for Action!");
lcd.print("Coms 1 - Ready for Action!");
delay(5000);
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
// make the pins outputs:
pinMode(ledPin, OUTPUT);
digitalWrite( ledPin, LOW );
lcd.clear();
mySerial.print(start); //SEND start CODE TO DaisyChain Middle !!!// - //"start = 0"//
Serial.print("start"); ///just for debug
Serial.print(",");///just for debug
// this code above will be moved to void loop, just here to send 1 test run
if (mySerial.available()>0)
{ //waits until data recieves
counter = counter+1; // counter starts at 0, increrment straight away so we start with #1
incoming = mySerial.read(); //read return data from DaisyChain_Middle
statusStore[counter] = incoming;
Serial.print(statusStore[counter]);
lcd.print(statusStore[counter]);
lcd.print(",");
Serial.print(",");
CODE: DaisyChain Middle
#include <Wire.h>
int IntTheNumber, incoming = 0;
int start = 0;
while (!Serial) {
if (Serial.available() > 0 )
//----x--------x--------x----
// LED LED LED LED LED delay start
start = Serial.read();
//send start signal to next one Variable start is = 0
//send data back to home base
Serial.write(9);
delay(10);
// LED LED LED LED LED delay end
digitalWrite( ledPin, HIGH );
if (mySerial.available() == 1 )
delay(50);
Serial.write(incoming);
CODE: DaisyChain End
#include <Wire.h>
int IntTheNumber = 0;
int start = 0;
while (!Serial) {
if (Serial.available() == 1 )
//----x----
delay(50);
Serial.write(62);
