Hi!
I've been trying to have two Beetle BLEs to communicate to each other with Bluetooth. One reads two analog sensors and constantly transmits data (two ints) to the other, so I use example 5 from the serial input basics tutorial by putting it in the receiving Arduino:
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 255;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
// variables to hold the parsed data
char messageFromPC[numChars] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
boolean newData = false;
Serial.println("This demo expects 3 pieces of data - text, an integer and a floating point value");
Serial.println("Enter data in this style <HelloWorld, 12, 24.7> ");
recvWithStartEndMarkers();
if (newData == true) {
strcpy(tempChars, receivedChars);
// this temporary copy is necessary to protect the original data
// because strtok() used in parseData() replaces the commas with \0
parseData();
showParsedData();
newData = false;
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // get the first part - the string
strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
integerFromPC = atoi(strtokIndx); // convert this part to an integer
floatFromPC = atof(strtokIndx); // convert this part to a float
void showParsedData() {
Serial.print("Message ");
Serial.println(messageFromPC);
Serial.print("Integer ");
Serial.println(integerFromPC);
Serial.print("Float ");
Serial.println(floatFromPC);
The code works fine when I put something in the serial monitor (even when I put only two pieces of data in a bracket)...but not when I actually transmit data from another Arduino. Instead, the serial monitor of the receiving Arduino would either show nothing but the prompt or print the transmitting data verbatim. I wonder why? The transmitting Arduino is powered by external power.
Code of transmitting Arduino:
int const piezo1Pin = A3;
int const piezo2Pin = A2;
pinMode(piezo1Pin, INPUT);
pinMode(piezo2Pin, INPUT);
unsigned long timer = millis();
int piezo1Value = analogRead(piezo1Pin);
int piezo2Value = analogRead(piezo2Pin);
Serial.print("<");
Serial.print(piezo1Value);
Serial.print(", ");
Serial.print(piezo2Value);
Serial.print(">");
delay(20-millis()+timer);
Thanks!
