Serial Communication Between ESP32 and TI C2000 microcontroller
Dear All,
I am using ESP32 to receive data from TI C2000 microcontroller (28027) . The code for the ESP32 is
#include <HardwareSerial.h>
#define RXD2 16
#define TXD2 17
HardwareSerial SerialPort(2); // use UART2
LiquidCrystal_I2C lcd(0x27,16,4);  // set the LCD address to 0x3F for a 16 chars and 2 line display
//HardwareSerial SerialPort(2); // use UART2
int data;
  SerialPort.begin(9600, SERIAL_8N1, RXD2, TXD2);
  lcd.init();
  lcd.clear();
  lcd.backlight();      // Make sure backlight is on
    while(SerialPort.available())
      lcd.clear();
     // data=SerialPort.read();
      data=1234;
      lcd.setCursor(1,0);   //Set cursor to character 1 on line 0
      lcd.print(data);
      Serial.println(data);
here if i uncomment the line data=SerialPort.read();
and also keep data=1234 in the second line;
The entire loop only works once.
If i comment data=1234; then the output is 0 (which is shown both in LCD and Serialmonitor and it only shows once.
Is the code written to receive data from an external microcontroller correct?
data is declared int and will be printed as an integer. To print the characters received, it has to be so declared, or typecast, e.g.
Serial.print((char) data);
Depends on how you have it wired. Is the TI C2000 microcontroller a 3.3V processor, or do you have a voltage mismatch?
Thanks jremington for the reply
The microcontroller (TMS320F28027) is a 3.3V controller.
But why is data showing 0 when reading from is Rx Tx Pins (GPIO 16,17). why nothing else
Also why its not looping.
As a first test I'd only echo each character from SerialPort to Serial.
  if (SerialPort.available() Serial.write(SerialPort.read());
Disclaimer: Untested :wink:
Indeed, but the code has a missing parenthesis:
  if (SerialPort.available()) Serial.write(SerialPort.read());
Post a wiring diagram and/or a photo of the setup. Are the grounds connected? Have you checked wiring continuity? Are you sure data are actually being transmitted?
Baudrate mismatch?
When I tried this code. I am not getting any information on serial monitor.
I am using GPIO 28 29 (TMS320F28027) for the serial communication. In the watch register of code composer studio I am able to see the change in values. The ground is connected between (TMS320F28027) and ESP32. Please note that both of these microcontrollers are also connected to PC, does this affect the communication.
The baud rate is 9600.
I am attaching the code for both ESP32 . Tx Register for TMS320F28027 is also showing values (screen shot attached)
#define RXD2 16
#define TXD2 17
uint16_t data;
  lcd.init();
  lcd.clear();
// if(SerialPort.available())
//       lcd.clear();
//       lcd.setCursor(1,0);   //Set cursor to character 1 on line 0
//       lcd.print(data);
//       Serial.println(data);
This is an too unprecise description
which code is "this code"?
What exact "register" are you watching and what values do you see?
Just to name a random name that could be related to it:
Is this the serial-buffer-output-register?
What voltage-level does the TMS320F28027 have? 5V or 3.3V?
You did not provide this detail
To what
  • baudrate,
  • parity,
  • number of startbits
  • number of stopbits
is the serial interface of the TMS320F28027 configured?
You have put together a system with many parts where each part has many parameters that could be the problem.
At the moment you are using a new code on the arduino from which you do
not
know if the arduino-code is working properly
trying to figure out if communication with your TMS320F28027-µC is working.
The method for developping such systems is:
  • Reduce the system as much as possible.
  • For testing use "partners" or devices that are well known to work properly
As a first test you should do receiving from your TMS320F28027-microcontroller to a TTL-COM-Port-adapter and look at what you receive in a serial terminal-software.
Or using a 24 MHz 8 channel logic analyser for $15 and record what is happening on the Tx-line of your TMS320F28027-µC.
If for whatever reason the TMS320F28027 does not send anything any testing above the level
of pure hardware-voltages is useless.
best regards Stefan
