Serial Communication between two Arduino boards for sending 2 sets of integers
Go to Serial input basics: example 5;
Simple untested modification for 2 ints...
SENDER ARDUINO
Serial.print("<123,456>");
RECEIVER ARDUINO
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
      // variables to hold the parsed data
int integerONE = 0;
int integerTWO = 0;
boolean newData = false;
    Serial.println();
    recvWithStartEndMarkers();
    if (newData == true) {
        strcpy(tempChars, receivedChars);
            // this temporary copy is necessary to protect the original data
            //   because strtok() used in parseData() replaces the commas with \0
        parseData();
        showParsedData();
        newData = false;
void recvWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void parseData() {      // split the data into its parts
    char * strtokIndx; // this is used by strtok() as an index
    strtokIndx = strtok(tempChars, ","); // this continues where the previous call left off
    integerONE = atoi(strtokIndx);     // convert this part to an integer
    strtokIndx = strtok(NULL, ",");
    integerTWO = atoi(strtokIndx);
void showParsedData() {
    Serial.print("Integer ONE");
    Serial.println(integerONE);
    Serial.print("Integer TWO");
    Serial.println(integerTWO);
