Serial communication btween arduino Uno & Nodemcu
I would like to communicate Serially with arduino uno & Nodemcu unit.
Here is thing what i am looking for. Nodemcu will send request in hex 01 03 006B 0003 7687 as character & arduino should match hex string and reply Serial String.
Below code is serial communication example.
Arduino code
#include <dht.h>
dht DHT;
int temp,humi;
#define DHT11_PIN A0
String str;
void setup(){
 Serial1.begin(115200);
 Serial.print(char(169)); // Copyright Symbol
 Serial.println(" Myengineeringstuffs.com");
 delay(2000);
  DHT.read11(DHT11_PIN);
  humi=DHT.humidity;
  temp=DHT.temperature;
  Serial.print("H: ");
  Serial.print(humi);
  Serial.print("% ");
  Serial.print(" T: ");
  Serial.print(temp);
  Serial.print(char(176));
  Serial.println("C");
  str =String('H')+String(humi)+String('T')+String(temp);
  Serial1.println(str);
  delay(5000);
nodemcu code
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
void loop() { // run over and over
  if (Serial.available()) {
    Serial.write(Serial.read());
you can test both with Serial Monitor
I have tested this code . I found node mcu reset . Previous code works well
But i would like to send request in hex if datais valid response ok else not ok
Ard_code
int val = 0;
int incoming = 0;
int incoming1 = 0;
  Serial.begin(115200);  //Begin Serial to talk to the Serial Monitor
  Serial.println("Serial Monitor Connected");
  Serial.parseInt();     //clear any garbage in the buffer.
  //     From the Rx Arduino
  incoming1 = Serial.available();
  while(incoming1 != 0)           //While there is something to be read
    val = Serial.parseInt();    //Get new value
    Serial.print("Receiving...  ");
    Serial.println(val);        //Print new value to the Serial Monitor
NodeMCu_code
int val = 0;
int incoming = 0;
unsigned int i;
byte Send_buf[] = {0x01,0x03,0x00,0x00,0x00,0x0a,0xFD};
  incoming = Serial.available();
  while (incoming != 0)                 //While there is something to be read
  Serial.write(Send_buf[0]);
  //delay(200);
i Have tested simple code on both device
If i connect USB to Serial converter and send any data with below code it will be reflected arduino comport. if i connect both device serially it wont connect. Arduino uno only print "started" from Node MCU.
From docklight i m sending welcome for every 5sec . I dont know why its not printing
Nodemcu code
#include "SoftwareSerial.h"
const byte rxPin = 13;
const byte txPin = 15;
SoftwareSerial mySerial (rxPin, txPin);
  mySerial.begin(115200);
  Serial.print("Started");
  if(mySerial.available())
    String incomingMessage = mySerial.readString();
    Serial.println(incomingMessage);
Arduino code
const byte rxPin = 2;
const byte txPin = 3;
you can't use SoftwareSerial at 115200. 19200 baud max
I have done Below modification
arduino code
 // mySerial.begin(115200);
 // Serial.print("Started");
  if(Serial.available())
    String incomingMessage = Serial.readString();
Nodemcu code
If i send any data from nodemcu it will be printed Arduino comport. If i send any string from arduino port it wont be printed. Let me check Softwareserial baudrate to 9600
My question is nodemcu baudrate is 115200 . weather it communicate if baudrate fixed to 9600. Software serial function not worked in nodemcu so i used Actual TX and Rx lines
do not use USB of the NodeMcu, if you connected Serial RX/TX of esp8266 to Arduino. the reasin is same as in the Uno. it is the same interface the USB and the RX/TX pins
I have change baudarte 9600 . Individually checked Software serial library with USB to ttl converter . Its working fine. When i paste same code in Individual Model & tx_Ard to rx_Node & Tx_node to Rx_ard
It wont reply . For nodeMcu if i directly use Serial communication it only read the data from Arduino But it wont reply for nodemcu
I have tested code with arduino Uno and Docklight for communication . Independently Software Serial works fine on Both Boards. Problem caused when same code used on both ic with relevant PIn config
I have attached my response in previous thread,
Since there 2 serial port is avilable on nodemcu .. How can i use second one
If i use serial.print primary it work
if i use SoftwareSerial secondary will work
but nodemcu say 2 hardware serial like arduino mega how can i use it
  Serial1.print("Started");
  if( Serial.available())
  Serial1.println("welcome");
  //delay(5000);
the Serial1 has only TX. io 2
