I am wondering if you can help me out, I am trying to build a serial communication between my Next-PM sensor and my arduino. I have tried to use Serial1 and also by using sercom3 on pin 0,1 but no luck, the sensor's application passed on TimeOut and I got nothing on Serial Monitor. I used the same code on Arduino MKRWifi 1010 and it worked perfectly.
Here is my code:
#include <SigFox.h>
#include <Arduino.h>
#include "wiring_private.h"
const byte numChars = 7; //avec le \n à la fin...
const byte MaxByteArraySize = 3;
byte byteArray[MaxByteArraySize] = {};
char receivedChars[numChars]; // an array to store the received data
const byte MaxByteArraySizeResponse = 16; //*********
byte responseArray[MaxByteArraySizeResponse] = {};
Uart SerialNPM (&sercom3, 0, 1, SERCOM_RX_PAD_1, UART_TX_PAD_0);
boolean newCommand = false;
boolean newResponse = false;
void hexCharacterStringToBytes(byte *byteArray, char *hexString)
bool oddLength = strlen(hexString) & 1;
byte currentByte = 0;
byte byteIndex = 0;
for (byte charIndex = 0; charIndex < strlen(hexString); charIndex++)
bool oddCharIndex = charIndex & 1;
if (oddLength)
// If the length is odd
if (oddCharIndex)
// odd characters go in high nibble
currentByte = nibble(hexString[charIndex]) << 4;
// Even characters go into low nibble
currentByte |= nibble(hexString[charIndex]);
byteArray[byteIndex++] = currentByte;
currentByte = 0;
// If the length is even
if (!oddCharIndex)
// Odd characters go into the high nibble
// Odd characters go into low nibble
currentByte = 0;
void dumpByteArray(const byte * byteArray, const byte arraySize)
for (int i = 0; i < arraySize; i++)
Serial.print("0x");
if (byteArray[i] < 0x10)
Serial.print("0");
Serial.print(byteArray[i], HEX);
Serial.print(", ");
byte nibble(char c)
if (c >= '0' && c <= '9')
return c - '0';
if (c >= 'a' && c <= 'f')
return c - 'a' + 10;
if (c >= 'A' && c <= 'F')
return c - 'A' + 10;
return 0; // Not a valid hexadecimal character
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (Serial.available() > 0 && newCommand == false) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newCommand = true;
void convertNewData() {
Serial.print("Command = ");
Serial.println(receivedChars);
hexCharacterStringToBytes(byteArray, receivedChars);
//Serial.println(sizeof(byteArray));
dumpByteArray(byteArray, MaxByteArraySize);
void writeCommand() {
SerialNPM.write(byteArray, sizeof(byteArray));
newCommand = false;
newResponse = true;
void readResponse() {
SerialNPM.setTimeout(500);
// size_t receivedBytes = SerialNPM.readBytes(responseArray, MaxByteArraySizeResponse);
dumpByteArray(responseArray, MaxByteArraySizeResponse);
void printResults() {
if (responseArray[0] == 0x81) {
if (responseArray[1] == 0x11) {
Serial.println("Concentrations readings averaged over 10 seconds and updated every 1 second:");
resultPrinter(responseArray, MaxByteArraySizeResponse);
resultPrinter2(responseArray, 8);
if (byteArray[1] == 0x12) {
Serial.println("Concentrations readings averaged over 900 seconds and updated every 60 seconds:");
if (byteArray[1] == 0x13) {
if (byteArray[1] == 0x14) {
Serial.println("Temperature and humidity readings:");
if (byteArray[1] == 0x15) {
Serial.println("Power on or sleep mode:");
if (byteArray[1] == 0x16) {
Serial.println("Sensor state’s readings:");
void resultPrinter2(const byte * byteArray, const byte arraySize) {
byte value0 = 0;
unsigned int value1 = 0;
unsigned int value2 = 0;
value0 = byteArray[2];
for (int b = 7; b >= 0; b--)
Serial.print(bitRead(value0, b));
value1 = word(byteArray[3], byteArray[4]);
Serial.print("Temperature = ");
float temp = (float(0.9754) * (float)value1 - float(4.2488)) ;
Serial.println(temp);
value2 = word(byteArray[5], byteArray[6]);
Serial.print("Humidity = ");
float humi = (float(1.1768) * (float)value2 - float(4.727)) ;
Serial.println(humi);
void resultPrinter(const byte * byteArray, const byte arraySize) {
byte value0 = 0;
unsigned int value3 = 0;
unsigned int value4 = 0;
unsigned int value5 = 0;
unsigned int value6 = 0;
Serial.print("PM1 pcs/mL = ");
Serial.println(value1);
//SigFox.write(value1);
Serial.print("PM2.5 pcs/ mL = ");
Serial.println(value2);
value3 = word(byteArray[7], byteArray[8]);
Serial.print("PM10 pcs/ mL = ");
Serial.println(value3);
value4 = word(byteArray[9], byteArray[10]);
Serial.print("PM1 μg/m3 = ");
Serial.println(value4 / 10);
value5 = word(byteArray[11], byteArray[12]);
Serial.print("PM2.5 μg/m3 = ");
Serial.println(value5 / 10);
value6 = word(byteArray[13], byteArray[14]);
Serial.print("PM10 μg/m3 = ");
Serial.println(value6/10);
#define i =5;
if (!SigFox.begin()) {
Serial.println("Unable Sigfox ");
return;
SigFox.debug();
SerialNPM.begin(115200, SERIAL_8E1);
pinPeripheral(0, PIO_SERCOM); //Assign RX function to pin 0
pinPeripheral(1, PIO_SERCOM);
Serial.println("Concentrations readings averaged over 10 seconds and updated every 1 second = 81116E");
Serial.println("Concentrations readings averaged over 60 seconds and updated every 10 seconds = 81126D");
Serial.println("Concentrations readings averaged over 900 seconds and updated every 60 seconds= 81136C");
Serial.println("Temperature and humidity readings = 81146B");
Serial.println("Power on or sleep mode = 81156A");
Serial.println("Sensor state’s readings = 811669");
Serial.println("Firmware version readings = 811768");
Serial.println("Type something:");
short valA = 128;
short valB = 128;
float valC = 654.32;
SigFox.beginPacket();
SigFox.write(valA);
SigFox.endPacket(true);
pinMode(7, OUTPUT);
pinMode(5, INPUT);
digitalWrite(7, LOW);
void loop(){
recvWithEndMarker();
if (newResponse == false) {
if (newCommand == false) {
convertNewData();
writeCommand();
readResponse();
printResults();
if (SigFox.parsePacket()) {
Serial.println("Response from server:");
while (SigFox.available()) {
Serial.print("0x");
Serial.println(SigFox.read(), HEX);
SigFox.begin();
if(digitalRead(5) == HIGH)
SigFox.print("139");
else {
SigFox.print("146");
digitalWrite(7,HIGH);
SigFox.endPacket();
void SERCOM3_Handler()
SerialNPM.IrqHandler();
