serial communication for two servos
Does anyone have a code that would allow me to manually input the position of two servos using the serial monitor function? The code i an currently using is giving me:
servos2.cpp: In function ‘void loop()’:
servos2:27: error: expected ‘,’ or ‘;’ before ‘while’
servos2:68: error: expected `}’ at end of input
Can someone fix my code or provide me with one that works. Thanks. Here is what I have so far:
/* two servo controller
serial input format
  protocol;motor_number=angle
  ex: 1=180@ or 2=56@
#include <Servo.h>
Servo servo1;
Servo servo2;
int inByte = 0;
char buf[256];
char stopByte='0';
  servo1.attach(10);
  servo2.attach(9);
  Serial.println("I am ready");
  int i=0
  while(true)
    if (Serial.available() > 0);
      inByte = Serial.read();
      if(inByte==stopByte)
        buf[i]='\0';
        break
      buf[i]=inByte
      i++
      Serial.print("I received: ");
      Serial.println(inByte);
  Serial.print("I received string: ");
  Serial.println(buf);
  char motor = buf[0];
  int k = 2
  while(buf[k] != '\0')
    buf[k-2] = buf[k];
    k++;
  buf[k-2] = '\0';
  int angle=atoi(buf);
  if(motor == '1')
    Serial.print("Motor is 1, and angle is: ");
    Serial.println(angle);
    servo1.write(angle);
  else if(motor == '2');
    Serial.print("Motor is 2, and angle is: ");
    servo2.write(angle);
Don’t cross post the same thing within a few seconds of each other please. Make up your mind where you want to ask the question and ask it once. Other thread removed.
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the # button above the posting area.
You're semicolons are all over the place. You're missing tons from assignment statements and have extraneous ones after selection statements.
These lines need semicolons:
  int i=0
        break
      buf[i]=inByte
      i++
  int k = 2
These lines almost certainly don't:
