Is the 'higher' level function that uses setTimeout. setTimeout(20) looks ok for a delay(100) between sending the csv data.
You could use my SerialComs class. This tutorial Arduino to Arduino via Serial has a CSV example. SerialCom synchroizes the send/receives so that there is no Rx buffer overflows even with long delays on either side.
I suggest you remove the motor stuff to start with and just get the coms running and then add the motor back in as a separate 'task'
See Multi-tasking in Arduino which has a complete stepper example
driven by Serial input and a sensor.
