I am trying to interface to a EFX-Tek RC-4 Board using serial communication. The RC-4 is a relay board and in order to control it, it needs to be sent a string like this ("!RC4", %00, "R", 1, 1). Does anyone have any suggestions on how to send this string?
Sigh. No it doesn't. What horrible documentation, hopelessly confusing the string "on the wire" with the command you have to give to a basic stamp to send that string. Double Sigh.
The RC4 uses the "AppMod" protocol from Parallax. I couldn't find a formal description of the protocol, but some of the documentation for the parallax add-on boards is a little better. It looks like a command starts with a '!' character, followed by two bytes worth of board type ("RC"), one byte of "unit address" (binary for the RC4), followed by a command and arguments for the command (whose format is apparently device specific.) So for the RC4 the command will look like "!RC4.R..", where the first "." is a binary zero, the second and third dots are binary 1.
So you might do something like
RC4_reset_relay(which, state)
Serial.print("!RC4"); // Preamble and device identifier
Serial.print(0, BYTE); // which board (always zero)
Serial.print('R', BYTE); // command to set/reset individual relay
Serial.print(which, BYTE); // output which relay
Serial.print(state, BYTE); // and what state we want.
