serial communication I2C protocal propgram
is the given program is correct for one slave device(69) ...writing ....in two address named 08 and 09 ... amd two datas 06 and 25...
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Wire.beginTransmission(D2); // transmit to device #address 69h(110 1001) write(LSB 0) = (11010010)
Wire.write(08); // register address
Wire.write(06); // data
Wire.endTransmission(); // stop transmitting
delay();
Wire.write(09); // register address
Wire.write(25); // data
delay();
Pavan_arduino:
It is enough to execute the following codes:
#include <Wire.h>
  Wire.beginTransmission(0x69); //not D2=1101 0010 ; 1101001 (0x69, slave address); 0 (write mode)
  Wire.write(0x08);        // register address
  Wire.write(0x06);        // data for register with internal address 0x08
  Wire.write(0x25)         //data for register with internal address 0x09 (the next higher one)
  Wire.endTransmission();    // transmit the above queued data and bring STOP condition on I2C Bus
BTW:
1. The slave address is always 7-bit. When the Master want to transmit (write) data to the salve, the master send this byte : 7-bit slave address + write bit (0) to the slave. Th following diagram (Fig-1) depicts the formation mechanism of the Control Byte (slave address + read or write bit = 8-bit).
Figure-1: Control byte formed using slave address + read or write bit
How do you know without knowing what type of device OP addresses? Not every device allows to write multiple bytes to consecutive register addresses although this is a common feature.
