Serial communication is not established
hi, Where am I making mistakes? It does not work.
#include <SoftSerial.h>
#include <TinyPinChange.h>
SoftSerial mySerial(2, 3);
char data = 0;
  pinMode(1, OUTPUT);
  if(Serial.available() > 0)
    data = Serial.read();
    Serial.print(data);
    Serial.print("\n");
    if(data == '1')
      digitalWrite(1, HIGH);
    else if(data == '0')
      digitalWrite(1, LOW);
I dont know English. Sorry if translation is faulty.
Are you wanting to read from the hardware serial line, Serial, or from the SoftSerial instance, mySerial, that you created?
You appear to be using, and intend to use, a software serial on pins 2,3, but the code in setup and loop addresses "Serial" i.e. hardware serial, rather than "mySerial".
Delta_G:
Nick_Pyner:
You appear to be using, and intend to use, a software serial on pins 2,3, but the code in setup and loop addresses “Serial” i.e. hardware serial, rather than “mySerial”.
thank you
SoftSerial mySerial(2, 3); // RX, TX
char data = 0;
  mySerial.begin(9600);
  pinMode(1, OUTPUT);
  if(mySerial.available() > 0)
    data = mySerial.read();
    mySerial.print(data);
    mySerial.print("\n");
    if(data == '1')
It worked like this. Thanks for your help
If you are not using the hardware serial pins for communication with the PC, get the device off of pins 2 and 3, and move the LED off of the hardware serial pin.
