So am having an issue getting my Robot code to work right. Its run through Windows 10 via Serial Com.
The Line BIGSERVOSW works when the button is pressed (and held), But it will not activate when Serial COM 5 is sent.
Same thing with the EXTRASERVO at the bottom.
I can not figure out why it work work with serial communication.
I also realize the very last item is not correct i am working on that yet/need to figure that out as well
PROGRAM:
#include <Servo.h>
#define BIGSERVOSW 5
#define EXTRASERVOSW 4
#define ROCK1 2
#define ROCK2 3
#define ROCKETFIRE1 12
#define ROCKETFIRE2 11
#define LED 10
Servo DoorServo;
Servo servo2;
Servo servo3;
char c;
String cmd = "";
pinMode(BIGSERVOSW, INPUT);
pinMode(EXTRASERVOSW, INPUT);
pinMode(ROCK1, INPUT);
pinMode(ROCK2, INPUT);
pinMode(ROCKETFIRE1, OUTPUT);
pinMode(ROCKETFIRE2, OUTPUT);
pinMode(LED,OUTPUT);
DoorServo.attach(7);
servo2.attach(6);
servo3.attach(9);
// LETS PULL UP THE INPUTS
digitalWrite(BIGSERVOSW, HIGH);
digitalWrite(EXTRASERVOSW, HIGH);
digitalWrite(ROCK1, HIGH);
digitalWrite(ROCK2, HIGH);
DoorServo.write(0);
servo2.write(0);
servo3.write(0);
digitalWrite(ROCKETFIRE1, LOW); //get back to default
digitalWrite(ROCKETFIRE2, LOW); //get back to default
digitalWrite(LED, LOW);
getSerial();
// Check for bigservo switch
if ( digitalRead(BIGSERVOSW) == LOW || cmd == "5")
/* according to "Then a Separate servo with its own button when pressed
moves a Large servo 120 degrees then returns when you let of the button" */
servo2.write(120);
while( servo2.read() != 120) //do nothing till servo come to 120
Serial.println(" BIGSERVO 120deg arrived " );
servo2.write(0); //bring servo back to 0
delay(500); //for debounce
else if ( digitalRead(ROCK1) == LOW || cmd == "1")
Serial.println(" ROCK1 pressed" );
DoorServo.write(95); // open the door for 95 deg
while( DoorServo.read() != 95) //do nothing till servo come to 95
delay(1000); // dealy for 1 sec
digitalWrite(ROCKETFIRE1, HIGH); //fire the rocket 1
delay(2000); //delay for 2 sec
Serial.println(" Rocket low" );
DoorServo.write(0); // close the door again 0deg
while( DoorServo.read() != 0) //do nothing till servo come to 0
Serial.println(" Door closed" );
cmd = "";
else if ( digitalRead(ROCK2) == LOW || cmd == "2" )
Serial.println(" Door opened" );
digitalWrite(ROCKETFIRE2, HIGH); //fire the rocket 1
cmd = "";
else if ( digitalRead(EXTRASERVOSW) == LOW || cmd == "3")
Serial.println(" EXTRASERVO Pressed" );
servo3.write(120);
while( servo3.read() != 120) //do nothing till servo come to 120
Serial.println(" EXTRASERVO 120deg arrived " );
while ( digitalRead(EXTRASERVOSW) == LOW || cmd == "EXTRASERVOSW") //do nothing till switch is being pressed.
{getSerial();}
Serial.println(" switch released" );
servo3.write(0); //bring servo back to 0
if ( digitalRead(LED) == HIGH || cmd == "6" )
digitalWrite(LED, HIGH);
if ( digitalRead(LED) == LOW || cmd == "8" )
else if ( digitalRead (ROCK1) == LOW ||cmd == "7" )
digitalWrite(ROCKETFIRE2, HIGH); //fire the rocket 2
delay(2500); //delay for 2 sec
digitalWrite(ROCKETFIRE2, LOW); // get back to default
delay(2000);
cmd = "";
void getSerial(){
cmd = "";
if(Serial.available()>0){
cmd = "";
c = Serial.read();
cmd = c;
while(Serial.available()>0){
cmd.concat((char)Serial.read());
