Serial communication Linux - microcontroller
Greetings.
I try to get the Arduion side to comunicate with the linux side via serial.
I tried IdeinoIO and firmata, but it's not really what, all I need is to send some messages from one side to the other, not set pins and such.
So, now i try to keep it as simple as possible.
See code below.
Sending data to arduino is simple, but the problem is when i try to send something back.
The problem is that when i try to send something back to linux side, it will trigger the linux console.
Is there any way to disable the linux console on the serial port?
EDIT:
I found the answer right after I posted this, but I can't delete the post anymore.
commenting the ttyATH0::askfirst:/bin/ash --login line from /etc/inittab seems to do the job.
on the linux side
var serialport = require('serialport');
var portName = '/dev/ttyATH0';
var sp = new serialport.SerialPort(portName, {
    baudRate: 115200
sp.open(function(err)
        if(err)
                return console.log('error opening port :<', err.message);
        setInterval(function() { sp.write('hello?');
and on the arduino the multi serial example
  // initialize both serial ports:
  Serial1.begin(115200);
  // read from port 1, send to port 0:
  if (Serial1.available()) {
    int inByte = Serial1.read();
    Serial.write(inByte);
  // read from port 0, send to port 1:
  if (Serial.available()) {
    int inByte = Serial.read();
    Serial1.write(inByte);
